Lowering block specs
From Perth WA
Ok ive just picked up a bunky Galant runaround and need to drop it down a lil bit! So if anybody has some 1200 lowering blocks laying around can you measure em up for me to see if they are modifyable?
Have a look in the pic plus i need the width too!
Cheers guys!
jpg  l block.JPG (17.14 KB)
5631_4afaa8686e058.jpg 631X454 px
Posted on: 2009/11/11 12:05
Chris...
Re: Lowering block specs
From south coast nsw
a:12mm
b:@15mm
c:110mm
d:8mm
e:13mm
edit: width was 50mm also
Posted on: 2009/11/11 12:21
From Perth WA
cheers buddy! your a champ!
Posted on: 2009/11/11 12:31
Chris...
From Perth
Wrong forums buddy
The Gaylant forums are over there >>>>
Posted on: 2009/11/11 12:52
Nothing to do with galants far as I know but I thought while were on the subject...uploaded this a whiles back in case any 1k owners found it useful.
Posted on: 2009/11/13 4:45
From Perth WA AUS
Nice job Wurzel, do you have one for the 1200?
Posted on: 2009/11/13 11:28
Datsun 1200 2Dr sedan.
Nah but from memory the 1200 ones ive seen were less complicated with just the straight up and down "lego" type connection as per beatties diagram about 10mm wide.
Re greendogs specs...shouldnt A=E and B=D or thereabouts?
Posted on: 2009/11/14 1:01
From Perth WA
I remember i modded some 1200 lowering blocks for my old thou. Just drilled the hole out in the bottom and found the perfect spacer at home for the top to make it larger.
But back on the off topic 1200 ones are way too small for the gaylant unless i get some shims made or somthing. Pretty close to the 1000 specs tho!
Neil, the mitsu forums are #OOPS#! Thats why ive come to the datto forum for my Mopar needs! :P
Posted on: 2009/11/14 1:41
Chris...
From perth airport
chris i have a set of 1200 lowering blocks $50 and there yours new in box with u bolts n stuff
Posted on: 2009/11/14 1:45
perth airport parking
Datsun 1200 ute A14
