« 1 ... 3 4 5 (6) 7 »
Re: A15 or L20b?? - Help me decide.
From RAdelaide
Go the l20, to the local plod not in the know, that motor looks at home in the bay.
But then again they know you to well!!........
Posted on: 2009/11/14 7:40
From Mildura, VIC
Hehehehehe thats true...
Posted on: 2009/11/14 8:46
From Mildura, VIC
Yep. - Series II bluebird sump, so is the motor - Looks like it't going to be a pretty easy fit.
Posted on: 2009/11/14 8:49
From Christchurch NZ
Yeah I had sump clearance issues when I did mine. We moddified the sump to clear the drag link, only to later discover that the sump from a bluey with rack and pinion already had the shape I needed. But you still wanna fit the engine with the wheels on full lock. as the steering aproaches full lock, the drag link rises. So what clears when your pointing straight ahead, might hit when you go around a corner. (or might prevent you going around it at all!)
Posted on: 2009/11/14 19:37
Forced Induction!
From Mildura, VIC
Still on the hunt for a good stumpy 5 speed box. I'm going to use a single 45mm Weber I think. - Keep it simple.
Posted on: 2009/11/15 3:15
You could also use a single 2 inch SU with a t28 :)
120 at the wheels with standard internals.
Posted on: 2009/11/15 7:24
From Mildura, VIC
Hmmmmmm
Posted on: 2009/11/15 8:21
From RAdelaide
anything with above 100kw rear wheels will be nice
Posted on: 2009/11/15 8:29
From Mildura, VIC
must.... resist... urge....
Urge to Turbocharge!!
Posted on: 2009/11/15 9:14
My A15 made 124 on "almost" standard internals..........
Posted on: 2009/11/15 9:50
Forced Induction!
