(1) 2 3 4 »
CA18DET into 1200 general questions
From Melbourne, Australia
Just curious if there is any tricks?
wiring is not usually a big deal for myself, i enjoy it
going to get ecu to engine loom, most stuff will plug straight up to motor, but what other inputs does the ECU require other than engine sensors?
inputs:
permanent power/ground
ignition signal
anything from tacho, speedo, gearbox? etc?
outputs:
fuel pump?
thermo fan?
pointing me in the direction of a wiring diagram would prob answer my questions
Posted on: 2009/12/16 9:18
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: CA18DET into 1200 general questions
From hastings,vic
check this postca wiring
Posted on: 2009/12/16 10:45
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
cool thanks,
next question
is it possible to use the stock dump pipe, using basically a mad dat crossmember to mount the motor?
Posted on: 2009/12/16 11:41
1200 Coupe Rallycar
ok so after having a look through the linked documents i have two concerns
1. speed sensor. is that in a skyline stumpy box? do people typically not connect this up?
2. ambient temp sensor. is anyone using that? where is it/what does it look like?
edit{} i dont see a manifold temp wire so i assume this is what ambient temp sensor refers to
Posted on: 2009/12/17 8:38
1200 Coupe Rallycar
Standard dump is not recommended, just spend the 250 and get a maddat one saves alot of fukin around. As for wiring, good thing is that the a has a engine room harness.. Need power to the ecu, output of ecu to fuel pump relay. Need a start signal to the ecu, that's jut what I can think of off hand oh and like u said constant power and ground ;)
Posted on: 2009/12/17 8:59
From Geelong
while we're on the topic, does the bellhousing in a manual 1200 really need to be changed? i know people have just 'massaged' the bellhousing to fit the stock ca box, is that legit?
Posted on: 2009/12/17 9:57
No tunnel mods needed if u have the patience of putting it in... I have no mods.
Posted on: 2009/12/17 11:08
From SE Melbourne
There's a couple of things not in the "EFI Loom", there is also an "Engine Loom" which has knock sensor, oil pressure switch, alternator on it.
You've got the CA18DET engine manual? (The Nissan FSM that is) - I'm sure you do it's all over the net, if not I can hook you up with one I did the OCR text recognition on...makes searching easy.
Posted on: 2009/12/17 22:46
Mildman, Datsunless
From Geelong, Vic
get one of those $30 stainless dump pipes from ebay or nissan silvia, they kinda fit. nothing a welder cant fix anyway
no ambient temp or manifold temp, only water temp
dont need speed sensor unless running the econometer or speed limiter
only sensors im running are
CAS
AFM
TPS
water temp sender
knock sensor
oxy sensor
Posted on: 2009/12/18 2:27
i just done have any sens ors ;)
Posted on: 2009/12/18 2:52
(1) 2 3 4 »
