Ca18det into 120Y
From Perth W.A
As the title says has anyone done it? what did they do? can you get a crossmember kit? has anyone done it in perth? how much does engineering cost? how much has the total cost?
using say a front cut and a brake upgrade and various other bits how much would it cost for the conversion using a stock engine?
i am wiling to give most of it a go i have done most of my car by myself as it is i know it's not much that ive done but hey i'm willing.
sorry for the long post and probably for the questions that have been done to death
Posted on: 2003/10/21 3:21
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
Re: Ca18det into 120Y
From Brisbane, Australia
x-member part of it is the same as for a 510/1600 or 610/180B as those x-members will bolt into the 120Y. X-members should be available for that swap from Matdat (or whatever its called). Should make that part of the conversion easier, if not cheap.
Posted on: 2003/10/21 4:31
From sutho shire
hay ca18det into a 120y will fit fine as tunnel is slightly bigger if u are going 2 use the stumpy box.. and slightly bigger engine bay.. the crossmember wound have 2 be fabricated up your self or a mechanic.. dumby fit motor as im positive they only make kits for 1200 ute..
it woul be a easieir coversion as u have disc's all ready on the front.. diff would have 2 be changed.. and new tail shaft, new fuel pumps,ect
all up expenses are usually about 6000$ for a conversion it seems alot but... well worth the fun and enjoyment and reliability /fuel efficiantcy..
Posted on: 2003/10/21 4:38
*1200 ute ca18det (CYA-18T)
256 rwhp at 14psi wanting more power
Team New skool
MADDAT CA18/1600 Fitting Kit x-xmember and engine mounts will bolt straight into your 120Y. You don't want the swaybar and tailshaft, but the g'box x-member may fit, or at worst be easily modified to fit.
Posted on: 2003/10/21 5:13
From Perth W.A
cheers guys, would i be better getting a front cut or would i be better off just getting engine gearbox and loom?
Posted on: 2003/10/21 5:35
120y Coupe
From Sid-knee
its been done in sydney at least... met this guy in July or August 2002 who took me for my first CA18DET experience.
Posted on: 2003/10/21 6:13
From Perth W.A
how much bigger are the SR20det and the Fj20det than the ca18, and What cars did they come in?
Posted on: 2003/10/21 6:20
120y Coupe
Quite a regular
From sunny QLd
sr20det come out of 200sx 180sx and silvia s14,s15 2 versions red top and black..black newer.. n suposibly better fuel wise ne ways
ca18det come out of silvias and 180sx
better motor than sr20 as bottem end is stronger alot of people say thay arnt but i have owned and driven both motors my prefference is ca18 higher reving and stronger..lighter.
fj20det geting long in the tooth..
hard 2 really get in good cond..
2 heavy and need 2 modifyed 2 get them really going... stock ca18det in a 120y will give u a very big smile trust me..
Posted on: 2003/10/21 7:12
From Perth W.A
cheers man, now i know theres more than 1 ca18 one is newer and better than the other, i know one has seperate coil packs or something.
and can anyone point me in the right direction for a ca18det front cut with gearbox and loom in perth, or even in adelaide i suppose?
Posted on: 2003/10/21 7:14
120y Coupe
Quite a regular
From Perth
try "r moore engines" in kewdale, they import, or at least used to import jap cars and jap engines / front cuts..
i hope to one day convert my little sunny into a ca18det street sleeper...
and with the back tyres smoking i will have to change the name from datsun sunny to datsun overcast!
chuck..day dreamer.
Posted on: 2003/10/22 4:57
