(1) 2 3 »
What do you know about the C200 diff?
From Christchurch NZ
Hey, I've been looking at a C200 LSD for fairly cheap. It looks just like a Borg Warner type 78, but apparently they are different. I did a wee bit of googling, and they (The net) reckon they run a clutch pack LSD and 29 spline axles.
It might be worth getting, but waht doe you guys know about them? it wouldn't be too hard to shorten one, and redrill the wheel stud pattern.
Posted on: 2010/1/12 7:36
Edited by A14force on 2010/1/13 7:08:08
Forced Induction!
Re: What do you about the C200 diff?
From Geelong, Vic
arent they patrol front diffs? what do they come in the rear of?
Posted on: 2010/1/12 7:58
Do you mean a Mercedes C200?
Posted on: 2010/1/12 23:29
Re: What do you know about the C200 diff?
Title edited.
No, I'm talking about a diff from a nissan called a C200.
Posted on: 2010/1/13 7:05
Forced Induction!
Oh, the C200 diff that is fitted to some Nissan D22 (Navara, Frontier) and D40 (Frontier) pickups.
It is a salisbury type, remove the gears from the axle housing, as it doesn't have a removable center.
This is a large diff, 200mm ring gear is 7.87".
D22 also came with H190 or H233 (in addtion to C200).
Posted on: 2010/1/13 7:38
LSD is about $1300 new at Nissan. You could cut the housing down for size, but what about the axles? Can they be shortened?
Posted on: 2010/1/13 8:08
From Taupo New Zealand
Navara diff. D21 as well as D22. Look quite heavy to me. But not as heavy as the terrano diffs. I don't like the idea of not beaing able to easily change the diff head much.
Posted on: 2010/1/13 9:12
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
From cranbourne, vic
mq/mk (km160, etc) fronts and i think g61 patrols as well, in patrols the ratio's were for mq/mk 4.11, 4.3, 4.6 and 4.88
you can get air lockers, auto lockers and detroit sp? lockers and the clutch type lsd from navara's
Posted on: 2010/1/13 9:55
82 1200 ute - daily
89 R31 H.M.A.S. Skyliner - drifter
197? 1200 coupe - new drift project.
85 CMA81 nissan/ud 9.5ton banana back - tow pig for the drifter.
Thanks guys.
I can get one for $200. If they are clutch type lsd, I might buy it. The ratio is pretty good too. The difficulty of pulling the center isn't a turnoff, but if it's going to be a orphan, that would be.
Posted on: 2010/1/14 8:07
Forced Induction!
Quite a regular
From Melbourne, Australia
the C200 diff is the live axle version of the R200. therefore, R200 LSD's can bolt into a C200 housing.
hope that helps people :)
stu
Posted on: 2010/1/14 8:35
(1) 2 3 »
