How do you check your charging Circuit ?
From Sri Lanka
Hi Guys
how do you check whether the alternator is charging you battery or not in a simple and easy way ?
thanks
Regards
sumith
Posted on: 2010/1/12 6:03
Re: How do you check your charging Circuit ?
From Adelaide, Australia
Disconnect battery while engine is running, engine should continue to run on charge from alt.
Posted on: 2010/1/12 6:17
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Sri Lanka
Hi Whitesedan
Thanks, no matter if it is positive end or negative end of the battery ?
Thanks
Regards
sumith
Posted on: 2010/1/12 6:33
Positive sumith, thats where the batt gets it charge from, through that fusible link wire thats attached to the pos battery cable.
Posted on: 2010/1/12 6:38
IPRA Build
Warning:
1. do not try this with newer cars. Those with electronic ignition or integrated-regulator alternator can sometimes be damaged. Like some late 70s Datsuns
2. do not leave the cable off for more than a second. The alternator output can go super high as it tries to regulate the voltage.
A more reliable test, easier too because you don't need to unbolt anything, is to use a voltmeter. At 1100 RPM, the battery terminals should read 13.5-15.0 volts. Too high is a problem you won't catch with the cable-off test, but you will with the voltmeter.
Posted on: 2010/1/12 7:18
check battery voltage when off... start car then re-heck voltage,,, voltage will be higher when running
Posted on: 2010/1/12 8:07
From Sydney, Australia
continuing from bailz..
and when you rev the engine, the voltage should not rise.
If the regulator is broken, the voltage will go well above the expected (normal) 13.8v -> 14.4v
Posted on: 2010/1/12 11:19
DO NOT disconnect the positive whilst the engine is running, The battery releases Hydrogen Gas, which is highly explosive, disconnecting the battery with this present will ignite and boom, uve got a battery exploding in ur face.
Best way to check is with a multimeter.
a fully charged battery will hold 12.6v.
A fully functional charging system on an older vehicle is around 13.8 or higher
Posted on: 2010/1/13 10:04
