« 1 2 (3)
Re: A14 HP
From Perth WA AUS
Mike or DD would be the best to answer that.
cc is the same but bigger intake ports.
Posted on: 2010/1/22 11:17
Datsun 1200 2Dr sedan.
Re: A14 HP
From Melbourne, Oz
The H89 chambers are better for making power because squish(I think thats the term, mind blank?) area witch is better for detonation, think the ports/valves are the the same on the H89 and H75.
Posted on: 2010/1/22 13:19
"I hav achieved wood"
Re: A14 HP
Yes.
* H89 is the "standard" A14 head. There are lower power ones.
* H89 has squish chamber (closed chamber)
* 1.5" pipe is enough for A14, 1.75 for a modded A14, but for 100HP fit a 2"
Posted on: 2010/1/22 21:53
Re: A14 HP
From Townsville, Qld
Have you had a read of this yet?
Posted on: 2010/1/23 0:27
Re: A14 HP
From Perth WA AUS
My inlet ports are bigger on the H89 than the H75, maybe someone did some work on it.
Posted on: 2010/1/23 8:36
Re: A14 HP
From Perth WA AUS
Just checked, my H89 inlets are 40x33mm.
Posted on: 2010/1/23 8:41
Re: A14 HP
Yes, someone ported them bigger.
Posted on: 2010/1/23 9:11
Re: A14 HP
You will spend more on an a14 to make good power than u will get from a ca and get reliable power
Posted on: 2010/1/23 12:51
Re: A14 HP
From Perth WA AUS
Gotta a point there!
Posted on: 2010/1/23 13:50
« 1 2 (3)
