WTD: CA18 engine parts
From Geelong, Vic
cant remember if i already put something up on here or not
but im after a pair of exhaust valves to replace the 2 that are bent in my head, thought someone might have a head pulled apart that they werent going to use the valves out of. otherwise its about $10ea for new ones
also after 1 or 2 DET exhaust cams to replace the DE ones i have. yes 2 exhaust cams not an inlet and an exhaust cam
so im hoping there are a couple of people out that that have blown up CAs that they can pull apart ot help me out
Posted on: 2010/2/7 11:09
Re: WTD: CA18 engine parts
From Geelong, Vic
any one?
Posted on: 2010/2/8 12:45
From mandurah
hey ive got a complete motor that i might be willing to strip for the right price for the cam and valves
Posted on: 2010/2/8 13:07
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Are the turbo exhaust valves sodium filled compared to the NA ones?
Posted on: 2010/2/8 13:18
From Geelong, Vic
not that i know of, all the rest of mine are just DE valves so it doesnt really bother me either way
estyre, how much would the right price be?
Posted on: 2010/2/8 14:05
From Geelong, Vic
bump
Posted on: 2010/2/12 0:38
From Geelong, Vic
no longer need cams, DE ones are the same specs as DET ones just with a different lobe centre
so mainly after a DET oil filter block thingo
Posted on: 2010/2/13 7:11
From mandurah
is that the one with the oil cooler pipes coming out of it ?
Posted on: 2010/2/13 7:44
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From Geelong, Vic
yeah thats the one, dont need the oil cooler though, just the alloy bit
Posted on: 2010/2/13 8:49
From mandurah
oh ok ive got a normal block piece that bolts to the block and tstraight to the filter
and ive got the same one but it has pipes on it for an oil cooler
hope this helps
Posted on: 2010/2/13 10:56
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
