« 1 (2) 3 4 5 ... 7 »
Re: datto ute handling (or lack of)
From Melbourne AUS
that could be a solution, but its just a band-aid solution.
body roll is terrible through corners, so if i can sort that it may fix the traction issue also
Posted on: 2010/2/14 8:03
1973 B110 A12
From Albury
Hey Ange
I'm only dumb but we got our ute to be a regular U2litre class winner at the winton sprints by continuously dicking with it.
Firstly get the best shocks you can buy.We went Koni adjustables front and rear and we do use the adjustment regularly depending on surface and conditions.
Secondly get the best tyres you can buy. We use toyo R888
an excellent tyre which will last for years with little or no loss to track times.
Thirdly piss off the overload springs on the rear. The softer springs will help with drive out of corners and help with rear end grip.
Good luck with it and keep on playing with it.
Bob
Posted on: 2010/2/14 8:22
From Melbourne, Australia
i have taken the oil out of front struts before and replaced with 20/50 motor oil (250ml for a stanza strut, but basically measure how much oil comes out and put that much back in
seemed to work well... but i was at uni then.... and new inserts arnt that expensive to a working man....
new shocks all round is the best thing you will ever do
and changing the rear springs... gotta do it!
Posted on: 2010/2/14 9:03
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Melbourne AUS
is the oil able to be changed in the strut without mods (ie cutting/welding)
if not then definately new inserts are the go.
but if i can change the oil easily i wouldnt mind trying that and replacing it with a better oil as a trial.
and yes i will definately take the load spring out of the rear, and install new shocks also.
any opinions on front coils? i wanna keep my ride height the same
thanks for all the help so far everyone
Posted on: 2010/2/14 9:09
1973 B110 A12
From Melbourne, Oz
King spring do race spring to messurment instead of to vehicle in various rates... hav a look and ask about, I think for hillclimb typ stuff ya want a 250-275lb spring?
Posted on: 2010/2/14 9:18
"I hav achieved wood"
cough - coil over front end- cough cough- any height you want- cough cough
Posted on: 2010/2/14 9:29
changing oil in struts is as simple as undoing the nut on top of the strut, tip the oil out, measure quantity, put new oil in, do nut back up
i dont know the full story on what oil would be there and what to use etc etc but 20W/50 seemed a good upgrade
i think there was an o-ring seal, probably worth replacing that as i think one of mine leaked a little after i'd done the mod
Posted on: 2010/2/14 9:44
1200 Coupe Rallycar
From Melbourne AUS
sounds like a worthwile exercise rc... thanks
unfam coilovers are definately an option down the track..
would like to play with different springs rates first though just to see how it changes the handling
when are you going to join me L-man?
Posted on: 2010/2/14 9:48
1973 B110 A12
From hastings,vic
i put the thick bottom ute spring on the top
flaten the spring pac out,lowerd car
no roll in the rear
Posted on: 2010/2/14 9:57
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
From Melbourne AUS
my rear springs are already reset lower. im a bit worried that taking the bottom leaf out might lower it furthur.
i know its only a helper spring but the top 3 leaves already seem to be sitting on it. hopefully the ride height
remains when i take it out. interesting point about reducing the roll in the rear though...
never thought about it that way.... i can see how it would help
Posted on: 2010/2/14 11:14
1973 B110 A12
