Five Forward Gear box
From Trinidad W.I.
I have a five forward gearbox, but its finger tip shifting and I want to work it up on my 210 which is floor shifting. Can this be done?
Posted on: 2010/2/17 19:13
Re: Five Forward Gear box
Yes, you can convert the RS5W60A from a Vanette to the FS.
RS = Remote Shift (column shift)
FS = Floor Shift
Vanette RS5W60A
Posted on: 2010/2/18 4:09
From Trinidad W.I.
Thanks a lot, I will work on that.
So all I need to do is remove the back section from my FS and bolt it onto the back of the RS?
Posted on: 2010/2/18 14:44
From Lisboa-Portugal
You can convert the remote shift to floor shift using a Pitroad Conversion Kit ( i think they don`t sell anymore).
Posted on: 2010/2/18 15:06
Yes, all you need is the rear case and assorted part (output shaft, etc) from a FS 5-speed. That's all that the Pitroad kit was.
It makes sense when you have a broken FS 5-speed and so can use the part to convert an RS 5-speed.
Posted on: 2010/2/18 23:36
It would be good if we could put the back of a 4 speed gearbox in a vannete gearbox and become a 5 speed fs gearbox!! wish it would be that easy!!!
Posted on: 2010/2/19 14:43
From Trinidad W.I.
Well its a 4 forward FS I have, would that be able to work up on the 5 forward RS?
Posted on: 2010/4/28 18:47
From Townsville, Qld
I'm thinking the shifter would be able to work from 4 to 5 speed, the only thing that limits it that there's no gears for the fork shape item inside to slide over when you try to grab 5th gear? or is the 60A 5 speeds extension housing larger?
Posted on: 2010/4/28 23:27
From Fremantle, West Australia
60 series floor shift 4 & 5 speed ext housings are a different spape
Posted on: 2010/4/29 12:04
