how hard is a CA18det conversion
From Sydney
how hard is this conversion? is it a straight fit n bolt in, and connecting wires and fuel lines?
Posted on: 2010/3/30 11:17
Re: how hard is a CA18det conversion
From Geelong, Vic
yes...everything bolts straight in and you just turn the key and away you go
but shouldnt you know that already?
Posted on: 2010/3/30 11:21
From Sydney
yeah i know but dose not hurt to learn more about these conversions
Posted on: 2010/3/30 11:26
From Geelong, Vic
see that search bar over there to the left, or the wiki. they are usually pretty good for answering the basics
how hard is the conversion, well i found it piss easy. others would probably find it really hard. at the end of the day its much like any other engine conversion. make mounts, do the plumbing and wiring, make a tailshaft and go
Posted on: 2010/3/30 11:31
From Adelaide, SA
not quite that easy, but there is alot of info on this site about it and there are alot of people who have done the coversion so most of the stuff you need is fairly strait forward to get. Ca's are becoming alot cheaper to pick up as well.
it also depends u can get a bolt in setup if u have cash burning holes in your pockets
Posted on: 2010/3/30 11:55
Car free
its is if you pay someone else to do it
Posted on: 2010/3/30 12:03
From Geelong, Vic
ah yes i should have added that it costs a minimum $1,000,000 to do a CA conversion also
Posted on: 2010/3/30 12:08
will be hard for u.... did u realise you posted in classifieds section?
Posted on: 2010/3/30 12:16
From Geelong, Vic
damn it, giving away all the answers for free when he wanted to buy them
Posted on: 2010/3/30 12:41
