(1) 2 3 4 »
Datsun down!!!!!!
From Atlanta, Georgia
Posted on: 2010/3/31 4:53
1981 Datsun B310
1973 Honda CB175 K7 Cafe
Re: Datsun down!!!!!!
lucky it wasn't a good one
Posted on: 2010/3/31 5:29
1200 ute unfinish'd sr20 $$$
1200 ute stocko
bumble bee drift pig
XR8 tow car / daily
bailz is orsum
what happened? wheel nuts still attached but you can see where the disk cut into the ashphalt?
doesnt this thing run on propane or lpg from memory
Posted on: 2010/3/31 5:33
From what we can tell so far, it appears that the lugs jumped ship. It landed pretty hard on the rotor, which happen to be brand new so I'm gonna have to replace it.
We picked up the lugs, jacked up the car and put the tire right back on. It seemed pretty solid, so we drove it home.
Our diagnosis at this point is that the vibrations from the loose steering caused by the worn tie-rod ends loosened it up a bit, because the other side was pretty loose too.
This one runs on pump gas. You must be thinking of another. I always wanted to convert to propane or something to the extent though.
Posted on: 2010/3/31 5:54
1981 Datsun B310
From Sydney
"Our diagnosis at this point is that the vibrations from the loose steering caused by the worn tie-rod ends loosened it up a bit, because the other side was pretty loose too."
lol face it dude you just didnt do them up tight enough(or who ever did them up didnt). Hmm should you be doing anything to that car if you cant even put wheels on properly??
Posted on: 2010/3/31 8:48
hahahah qaulity!
Posted on: 2010/3/31 9:08
From Perth WA AUS
No way I would post that out to the world if it was me!
Glad there is not much damage.
Posted on: 2010/3/31 12:58
Edited by levey on 2010/3/31 13:14:02
Datsun 1200 2Dr sedan.
From Albany, Perth Australia
that poor sunny!!! at least its fixable, are the wheel studs stretched and or ready to snap?
Posted on: 2010/3/31 13:06
1200 Smerf Mobile
x2
Posted on: 2010/3/31 13:33
1200 ute stocko
XR8 tow car / daily
bailz is orsum
LOVED the line "Thats how I wanted the tyre to sit but not under these conditions"
Glad you, passenger, rim and the car are OK.
Let it be a lesson to us all that it pays to check your nuts regulary, (and see that yr wheel is on properly once and a while too).
(1) 2 3 4 »
