TOP GEAR!!! 2 or 3 piece A series pro stock block
Being thinking of this for a while of a bike engine top end
with a car crankcase to suit common RWD gearboxes and finally
the mob that has done the hayabusa v8 has done the H2.
http://www.muzzys.com/ZX14/ZX14_Prostock/index.html
http://www.h1v8.com/H2.html
http://www.h1v8.com/h1h2pricing.html
However couldnt such a crankcase cost less than
8500USD !!!! just your opinion TOPGEAR or other
3d cad modeler dude.
My idea and there could be better would be a
3 piece block
lower case - unitary main caps and sump with flat
alloy plate cover plate bolted at the bottom.
mid case - holding the top part of the mains and completing the crankcase
(both units also with bolt pattern to suit W series box (still available
for hilux and hiace with interchangeability) or removable rear plate
to suit all sorts gearboxes)
Cylinder casing - the biggest piece of alloy billet for a bolt up pattern
to suit and aftermarket head
or option 2 - just dump this part and use the combined
crankcase and use other bike cylinder cases and heads.
Cheapest would be opt 3
Just the top part of the crankcase to suit bike crank,
cylinder casing and head with bolt up pattern on rear
to suit W series toyota box or t5 and custom unitary
Mains ladder brace and custom tin sump.
(gbox bolt up pattern will need some adaptors to suit
the bottom or top part of the engine (or both)
Opt3 would need the less amount of billet pieces
and should provide a cheaper option for those
wanting a good performer but not ruin your pockets.
jpg  zx14prostock.jpg (41.97 KB)
737_4bb3d616087a8.jpg 462X406 px
jpg  base1.JPG (32.59 KB)
737_4bb3d696bfc77.jpg 435X336 px
jpg  block base.JPG (36.96 KB)
737_4bb3d6a55bed7.jpg 448X316 px
Posted on: 2010/4/1 0:05
Re: TOP GEAR!!! 2 or 3 piece A series pro stock block
From windsor, sydney
$8500 is roughly 80 hours of 3d design and 4/5 axis cnc programing and machining ($250.000.00 machine ) then you have the cost of the alloy billett (6061 is $9/$12 per kilo)and you start with say 40 kilos and machine off 30/35 kilos and that goes in the scrap bin. $8500 may sound like a lot of money but if you did this same project in australia and on a one off baisis you wouldn't get much change out of $20.000.00. Go the american option they allready have all the bugs sorted out .
Posted on: 2010/4/5 10:48
WARDMAN ENGINEERING
CNC machining
Race Car Fabrication
Suspension, Brake, Drivetrain modification
TIG welding of all metals
0413 595 627
From perth
D you would go chev bell housing bolt pattern as you can get heaps of off the shelf bell housings
Ward the guys on here have $1000 cars mostly. itll never happen
Posted on: 2010/4/5 14:23
From mandurah
yeah darrens right if any of us could afford this setup we wouldnt be driving dattos
haha darren is my car worth $1000 lol
Posted on: 2010/4/5 15:07
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
I could go the china option, itll cost about 1000aud but wont fit anything
except the recycle bin :)
I suppose if you are going to go through this trouble of using 40kg of billet
alloy then you might as well aim for the v8 option.
As for most cars here only worth 1k surely they are worth more than 4 year old Taxis :))
Posted on: 2010/4/6 1:40
From Freo
What about a Top fuel Bike motor... yum..
Posted on: 2010/4/6 3:10
A15 PSI Project Motor
'72 CB750k,
oh year that's a nice piece of engineering ,only that it has no water jackets , straight line stuff only
Posted on: 2010/4/8 2:45
WARDMAN ENGINEERING
CNC machining
0413 595 627
From Freo
thats my Boss's Top Bike,
little changes all the time to keep you on your toes..
4 valves to 3, change the stroke,
clearance the block, support bearing here..
it's all good fun though..
Posted on: 2010/4/8 3:33
'72 CB750k,
Dundee 4 valves to 3 my kind of thing.
I love the 3 valve heads especially if they are for pushrods engines!
Pity chev dumped the progress of the variable 3 valve pushrod smallblock.
Only Barry Grant has a strange looking 3 valver now.
Posted on: 2010/6/5 14:02
From Perth
You can always use 4 valves on the Chevs with pushrods using the ARO heads
If you got enough coin
Posted on: 2010/6/6 3:15
