« 1 (2) 3 »
Re: 63a #3 - 5 speed dogleg install query
it came out of a 1600 stanza, it's the same length as my existing 4 speed gearbox, and has a cable not hydraulic clutch, can anyone else verify whether it'll bold straight up to my a series motor ?
Posted on: 2010/4/13 10:19
From Christchurch NZ
for the record, the A series 63a dogleg 5 speeds are hydraulic clutch.
IF you have the correct box for the A series motor, you're going to need to remove the factory mount points from the floor pan and either weld them back on further back, or fabricate a new Xmember, and create new mounting points. I used a home made X member, with reinforcing plates on the topside of the floorpan.
As for the clutch, I had my A series flywheel remachined to take a 200mm pressureplate, and the 200mm L series clutch plate.
Post a photo of the gearbox looking at the gearbox mating face, and we'll know right away if it's for an L or an A.
If it's an L box, forget adapting it, it's more work than it's worth.
Posted on: 2010/4/13 10:29
Forced Induction!
From Melbourne, Oz
there was no 1600 a series or a series stanza so it hasto be L
"I hav achieved wood"
Posted on: 2010/4/13 10:51
Posted on: 2010/4/13 10:52
From Melbourne, Oz
Yeah sorry dude thats an L
Posted on: 2010/4/13 10:54
yup it is I didnt think of checking that simple thing - just checked the view versus the manual :)
Posted on: 2010/4/13 11:00
From Adelaide, Australia
Yeah thats the same as I have in my 1200, with a L16...
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Yes, that 63A only fits L-series engine.
You need 63A for A-series engine. The Datsun 1200 auto driveshaft fits it.
If you find a broken 63A for A-series you *might* be able to swap the front casing. No one has actually tried this.
Posted on: 2010/4/14 3:22
I've done it. BUT, you need to turn down the input shaft as the L sereis input ID, is bigger than the Spigot bush OD of the A series. Plus it needs a bit cut off the end too, as the L series input id longer than the A series one.
Posted on: 2010/4/14 10:44
Forced Induction!
« 1 (2) 3 »
