60 series box info wtd
From hastings,vic
hav 60 4 speed out of vannet
want to convert to floor shift
from collum
thanks tommo
Posted on: 2010/4/16 16:32
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
Re: 60 series box info wtd
You need the rear transmission case & shifter parts.
So either find a broken floor-shift 4-speed ... or find a good one and discard the vanette transmission.
Posted on: 2010/4/16 17:06
From Perth WA AUS
I should be fitting mine within a couple of weeks if its no good I'll let you know and give you the parts you need, seems like a good box though.
Posted on: 2010/4/17 11:27
Datsun 1200 2Dr sedan.
Did all stanzas come with the 63a instead of the 60a on the L series?
Or are all 63a boxes 5 speed doglegs SSS instead?
- wished the dellow bellhousings where more affordable, Id evern
use the 4 speed t40 for its smoother shifting action.
Posted on: 2010/4/17 11:57
From Perth WA AUS
I think 63a is L series but could be wrong.
Posted on: 2010/4/17 11:59
From Perth WA AUS
Disregard that last post, I just checked:
The 63A came in two versions:
•63A to fit L-series engine
•63A to fit A-series engine
Posted on: 2010/4/17 12:02
From mandurah
levey that box is in good working order and it was running in the coupe with no problems ,but the xmember is the only problem ,as you need to drill holes in the floor for the xmember
if you dont want it ,i will buy it back to put in my ute any day ,cos my box is F U C K E D
Posted on: 2010/4/17 12:12
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Perth WA AUS
Yes i'm sure its in good nick but if my motor breaks it I might have some spare parts for sale!
Posted on: 2010/4/17 12:15
From mandurah
yea i wouldnt be suprised if it pops it
it will with you driving !!
Posted on: 2010/4/17 12:17
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From Perth WA AUS
Hehe, drive it like you stole it!
Posted on: 2010/4/17 12:27
