sr20 gearbox question
From Newcastle nsw
Ok, so i have been offered a sr20 with throttles, comp, gbox etc out of a s13 for what i think is cheap (well cheaper than workin the hell out of my a series) but im not fully convinced to do the conversion yet. I was wondering what gearbox easily fits in a manual tunnel, and do the gearsticks come out of the original hole??
Thanks guys
Josh
Posted on: 2010/4/20 11:47
Re: sr20 gearbox question
From mandurah
i would go for a CA18 as they are smaller and easyer to fit , but still have good power
and a CA gearbox will fit in a standard tunnel but you will need to cut a new hole about 100mm back for the shifter
it abit hard to fit the CA box in the standard tunnel but has been done heaps of times ,its just abit of a hassle changing the box or takeing the motor out
as for the SR20 im pretty sure the floor will have to have a bigger tunnel put in
and the shifter will be further back aswell
and ive heard that the SR20s in 1200s are abit front end heavy and dont handle
so i would go for the CA18DET and they can be regoed in 1200s in some states !
Posted on: 2010/4/20 12:36
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Geelong, Vic
SR gearbox is exactly the same size as a CA one, so it will fit in the same spot as a CA one will
Posted on: 2010/4/20 12:45
From Newcastle nsw
isnt a stumpy 5 spd shorter than standard s13 gbox?? can a stumpy box go on the back of a na sr?? Anyone done a sucessful conversion on here?
Posted on: 2010/4/20 12:50
From pooraka,,adelaide
i think if u get a rb20 box with ca belhousing it will b shorter then a ca one so might fit orgional hole? or maybe its a ca20 one? cant quite remember but one is shorter
Posted on: 2010/4/24 3:16
620 ute -sr20det full irs
vanette-a15 turb
260c- daily
1000 4dr- a15
1000 4dr- project to be sr20
garage 910
From Adelaide, Australia
a sr box in a 1200 makes the gearstick come out through where the handbrake sits
Posted on: 2010/4/24 7:46
parts needed: GX air filter box. for sale, stanza steering wheel, 1000 gloveboxes lids
From hastings,vic
stumpy with eather ca or sr gearbox front housing
and swap bearings to suit.
Posted on: 2010/4/24 8:30
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
