What wheel offsets do you run on the front of your 1000
From Sydney
I had a search and couldn't find anything. I'm trying to find a set of wheels for my 1000 coupe and its proving to be a hard task. Also someone who can measure it up and tell me what offsets I need is just as hard. To make things easier I have a h165 rear axle (widder track) so I will need a staggered offset.
Ive been looking at 16x6.5 and 16.7 but what size, width and offset have you guys used and any feedback would be good?
Posted on: 2010/4/28 23:45
Re: What wheel offsets do you run on the front of your 1000
From Perth
13x6
+6
Posted on: 2010/4/29 0:38
From Sydney
Do you know the clearnce between your rim and top control arm?
Posted on: 2010/4/29 1:21
From Melbourne Vic
13 x 7 +or-2
need camber on front and skinny tyres (165/75 atm)
fine on top arm
i used to run 13 x 6 + 16 from memory. close but no issue on top arm
Posted on: 2010/4/29 2:35
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
From Sydney
Maybe becuase you are running a smaller rim.
Thanks, keep it coming though. Anybody tryed bigger like 15" or 16"
Posted on: 2010/4/29 4:21
From Melbourne Vic
if you run a larger diameter wheel you can run a more positive offset wheel as it will go over the upper arm. to counter this tho, bigger wheels start to not suit the little 1000 as much (but only in my opinion) you'll start to run into problems with the wheels and guards during turning, you won't be able to have it sit as low, your brakes will be pulling up a greater rotational force from the larger diameter so there are other things you'll need to address, especially if going 16's or 17's
Posted on: 2010/4/29 4:44
From Sydney NSW
14's probably around 6" wide with 175/60 tyres needs guard work, they scrub on full lock. 13x6.5 around +20 clips the upper arm. Honestly if i'm having some trouble with 14's, imagine what trouble you would have with 16's.
Posted on: 2010/4/29 5:44
From Sydney
i was going to use the silhouette skyline rims from the r30 r31 ? dunno which model exactly but they seems to fit really nicely never drove with them on as car is still being built but now i have 15 inch x 4 inch on the front and heaps of room but not standard suspension anymore
the skyline rims
new rims
Posted on: 2010/4/29 11:06
Posted on: 2010/4/29 11:16
Car free
for 1200 about +30ish depending on break setup
Posted on: 2010/4/29 11:18
Car free
