power output on a t25 ar.46
want to no wat sorta power i can get out of a std t25 on a ca18det
Posted on: 2010/5/10 8:48
Car free
Re: power output on a t25 ar.46
From Sydney
i would go t28 gotta be more there..
Posted on: 2010/5/10 10:17
From brisbane
Hi mate
I never dynoed my car with the factory turbo. But, considering a CA puts out 130 flywheel kilowatts at 7psi from the factory (approximately 100-110rwkw depending on driveline losses and engine condition), it would be reasonable to assume that you would see somewhere in the vicinity of 115-135rwkw on 12psi (3-5kw/psi extra boost).
There are plenty of assumptions in the above but hopefully it gives you some indication of what's possible.
What I found was that anything above 12psi was pretty much pointless as it didn't seem to make anymore power. I assume this was due to being out of it's efficiency range and simply making extra heat rather than horsepower.
Matty
Posted on: 2010/5/10 11:19
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
From Canberra
I'm still running the standard T25 with just things like a frount mount, 3" exhaust and a diffrent computer at it makes about 150kw at 16 psi, but that's preety much its limit.
Posted on: 2010/5/10 12:08
YLD.18L
nice cant wait to get the ca in my coupe
thanks for the info im lookin at upgrading later on to a disco potato t28 and a few other things when i have funds and a rebuilt bottom end :)
Posted on: 2010/5/12 11:17
Car free
From penrith,sydney,aus
my old sedan made 122kw atw on 10psi
it was standard with a 2 1/2 in exhaust, front mount and a pod, that was through an auto too
Posted on: 2010/5/12 12:12
2 door 1200 sedan project l20b stroker
