« 1 ... 3 4 5 (6) 7 »
Re: 5 Speed adaptors? Which gearbox to use?
that actually sounds pretty good. If anything, I'd prefer to have the shifter a bit further to the rear. I'm not quite into the 'rip the front seats out and sit in the back' from police academy, but I am looking at relocating the seat as much as I can rearward, a revised shifter position would be great (even if I had to make a custom shift lever with scoliosis to help clear the handbrake lever.
Posted on: 2010/5/13 15:40
John McKenzie
From Geelong, Vic
with an auto tunnel you should be right for clearance, i always thought that the auto tunnels had the small bellhousing section like the manual ones...didnt know they were a whole new welded in tunnel
so now that i have seen a couple i'd say they are pretty similar to 120y/180b/200b sized tunnels
only mods i can see would possibly be lifting the tunnel a bit where the shifter would be as it tapers down a bit after the shifter
Posted on: 2010/5/14 9:48
From Ballarat Victoria
Thanks for that Nick. I`ll put some pics up of the welded A front section to the 71B box.
Posted on: 2010/5/14 12:29
So simon which box is most likely going to be for winton?
Posted on: 2010/5/18 2:06
From Wagga Wagga, NSW
Will any of these 5 speed options fit in a 1000 tunnel? If so im a keeeeeeeeeeen bean :)
Posted on: 2010/5/18 2:40
Ryan(Zigzag) says:
mmmmm men
Jake(tuf-110) says:
i thought you might say that
Ryan(Zigzag) says:
its raining men
Jake(tuf-110) says:
oh its your day
I`ll have the 260Z (71B) box in for winton.
Im not sure of the tunnel size in the 1000... Anyone else?
Posted on: 2010/5/18 6:08
From Geelong, Vic
anything will fit with a big enough hammer, or a 9 inch and welder
Posted on: 2010/5/18 6:30
True true, but the length available is not the same as the 1200 allows.
In the 1000 you sit a little forward compared to the 1200.
Im toying with the idea of finding a Nissan D21 gearbox with Bluebird
s3 ca20e 71 series internals.
Here are the pics of the box from the d21 its supposed to weight 35kgs.
The bluebird 71b series box has supposedly a 3.01 or 3.3 first which
would be better than the 3.9 or whatever the d21 is.
This d21 is the shorter one in the pic and has the 71c type of gear
shifting mechanism which would be better than the bush and pin type.
It is also an alternative to the rare stumpy r30 box.
jpg  d21box.jpg (69.81 KB)
737_4bf28e031e6a2.jpg 800X600 px
jpg  d21 pickup.jpg (84.15 KB)
737_4bf28e109bb8c.jpg 800X600 px
jpg  d21ute.jpg (78.15 KB)
737_4bf28e25d9889.jpg 800X600 px
Posted on: 2010/5/18 13:52
From Geelong, Vic
interesting. that comparison pic is to a silvia box im guessing, cant say i can tell the differnce between a silvia and a skyline 71c without having them side by side
so the d21 box looks to between a stumpy and 71b in length
wonder how much they go for
Posted on: 2010/5/19 0:23
I like the shifter mechanism and its compact size without the girth of the stumpy.
Posted on: 2010/5/19 3:53
