ca18det clutch setup
hi ppl was wondering if anyone know of any good clutches for a ca18det??
also if anyone knows if l series master and slave will be ok to use on a stumpy r30 on a ca18 bellhousing??
also some info about l series and ca18 clutch plate if they rar the same size and the pressure plate if u can swap between the 2??
thanks nick
Posted on: 2010/5/16 8:08
Car free
Re: ca18det clutch setup
From Geelong, Vic
im using a second hand extreme HD 5 puck in mine, seemed to work just fine
L series slave will work fine on the CA box, used the same hydro clutch setup for my L series and CA
CA is the same size clutch plate an L series 6 cylinder, 225mm
pressure plates have different bolt patterns, you could redrill an L series flywheel to CA pressure plate pattern if you really wanted to. then you could get really good clutches...that are also really expensive
an excedy HD clutch for an L series is about $180, for a CA its like $500-700
Posted on: 2010/5/17 2:03
Good point tip there Nick,
You mean CA flywheel drilled to take L series pressure plate pattern right?
Is there a 200mm HD clutch? Im thinking of using a smaller gearbox modded
by Simon maybe a 60 series L series 1600 box
Posted on: 2010/5/17 4:42
From Canberra
I've got ana Extreme clutch aswell with my CA18. It was recommended to me and although it has been in the car for a bit over a years worth of driving it's been through numerous 'spirited' stints and a theft and it's still perfect.
Posted on: 2010/5/17 4:47
YLD.18L
+1 for the extreme clutch. Except mine was the organic heavy duty version. Personally i havent found it wanting in any area actually
Posted on: 2010/5/17 8:18
can i use a l16 clutch plate with a ca pressure plate??
Posted on: 2010/5/17 11:08
Car free
From Geelong, Vic
no D i mean CA clutch on L series flywheel, CA would kill an L series clutch in seconds(maybe minutes)
CA pressure plates are over a thousand kgs of clamping pressure. a good L series one might be half that. 4agze ones are only like 750kg
and all 4 cylinder clutches are 200mm, apart from 720 and z18et
nick, no you cant use an L16 clutch plate with CA pressure plate, the L16 is 200mm. need a 6 cylinder clutch plate
Posted on: 2010/5/17 15:26
Im not liking the price differences, Id prefer a HD 200m clutch for 180aud
especially for a datsun 1000 which is much lighter and the owners foot has less lead in it :)
Posted on: 2010/5/18 2:11
