new A15 vs old A15 Power?
From mandurah
how much work needs to be done to the brand new A15s to suit a 1200 ?
ive heard that the cam isnt right for a road car and they dont rev as they are an industrial version
and are they as strong as an A15 out of a sunny ?
and are they the same gearbox pattern for a 56a or 60a gearbox ?
any help would be great
Posted on: 2010/5/22 9:14
Re: new A15 vs old A15 Power?
From Coondle, WA Australia
If you are talking about the a15s they they stuffed into forklifts and such, then yeah they wouldnt be much good for a road car, but thats not a big issue to fix. As far as I know the only real difference is that the cam (like you said) and the manifolds drop down lower to fit inside the engine bays.
Other than that, they are the same i believe.
Posted on: 2010/5/22 9:59
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From Melbourne, Oz
yeah see if you can get a car a15 cam? and get the comp ratio checked and maybe ignition curv
Posted on: 2010/5/22 10:29
"I hav achieved wood"
From mandurah
ok ,if the price is right for a brand new one ill get one ,but i have a feelikng that they wont be cheap at all
so put a car dizzy ,cam and manifold on one and it should be all apples
my plans were to buy a new A15 and hot it up abit (or alot) and use it in my ute as a dialy driver
Posted on: 2010/5/22 10:52
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
The brand new A15s fitted to the Vanette have a good cam in them. Only the industrial engines are low-RPM.
Posted on: 2010/5/23 3:59
From Freo
dude, why wouldn't you just buy a good second hand Big Block (A14-A15).. there's a few about..
Posted on: 2010/5/23 4:03
A15 PSI Project Motor
'72 CB750k,
From mandurah
well if anyone in perth has a good A15 block or complete motor for sale ide be keen on buying it ,but ide preffer a complete motor
Posted on: 2010/5/23 7:36
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From Freo
Mal has one,
Posted on: 2010/5/23 7:57
'72 CB750k,
From mandurah
A15 or 14 and do you know how much and could you PM me his number please ?
Posted on: 2010/5/23 8:01
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
