which is better... CA18det vs 4AGZTE
From Sydney
which is a better performing and cheaper swap both engines are turbo...
do maddat do engine conversion kits for 4AGE rwd?
Posted on: 2010/5/23 3:12
Re: which is better... CA18det vs 4AGZTE
More displacement is better for the same weight.
Go the CA18DET.
Posted on: 2010/5/23 3:53
From Sydney
but fiting it would take more work for a ca18det?
dose anybody do 4agzte engine conversion kits?
can it be enginnered with a 4agzte and top mount turbo?
im asking these because i found a 4agze turbo 1600cc rwd top mount turbo with 180kw for sale and with that power it should be decent ride?
Posted on: 2010/5/23 3:58
From Rosewood, QLD
i think its easier to fit the CA... if you want the 4agze slap it in a corolla.
Posted on: 2010/5/23 4:37
1971 B110 sedan project.
2012 Nissan Micra daily.
From mandurah
putting a CA in isnt at all hard ,for me it was harder putting my A14 in my ute ,but the Ca is easy because the mounts are kinda low ,but it does help when your rad support has been cut out
and plus keep a nissan a nissan not a toyota inbreed thing !
Posted on: 2010/5/23 5:22
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Sydney
lol fair point so cutting firewall? dose it need to be? can i just use the standard gearbox tunnel?
why do i have to cut the radiator suport for???
Posted on: 2010/5/23 5:39
From Sydney
is it possible to supercharge and turbo a ca18det?
Posted on: 2010/5/23 5:55
From Logan, QLD
you don't have to cut your radiator support, but it will make changing a gearbox alot easier if you squash your motor up very close to the firewall like most do.
Yes you can get a 4age engineered with turbo, as long as the mounts are done properly.
You only have to cut the gearbox tunnel if your gearbox does not fit, lol I know that sounds dumb but it depends on which engine conversion you do, which floorpan you have, which gearbox you choose, where you mount your motor.
as for the maddat mounts for a 4agte, check their site for one, they have most of their products listed I think. www.maddat.com i think.
There is nothing wrong with putting any other manufacturers motor in, choose whats best for the car you want to achieve, its your car, don't listen to others.
180kw would be a fun ride, 180rwkw would be even better. Both engines have alot of potential in a 1200 as they put the power to weight through the roof, I'd imagine you'll be doing or getting close to 12's. But it really depends on alot of things you do with your conversion.
Posted on: 2010/5/23 7:01
From Sydney
but can you engineer a car with top mount turbo?
Posted on: 2010/5/23 7:21
From mandurah
you could always put a low mount on and then once you pass rego you could put the top mount back !
Posted on: 2010/5/23 7:28
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
