« 1 (2)
Re: good price for surge tank???
From Sydney
Before you go down the ebay path, I would look at getting one made. It will fit heaps better and look neat. You can chose where to run lines in and out of the surge tank. You can run metal fuel lines up to your engine bay and you will only need 1 meter of fuel line. You dont need to run braid, i used a blue high pressure fuel line and briad for turbo lines only on exhuast side and it looks very neat.
Price it all up and if its only $100 or so more go with the custom job.
Posted on: 2010/5/23 9:32
From mandurah
for the price of that i would go for the ebay one cos there is about 200-300 bucks worth of fittings and line and then the price of the tank ,but i thought that surge tanks were suposed to be realy tall and skinny?
Posted on: 2010/5/23 9:44
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From South Africa
Gav, i hope you never have a prop fail on you, it will rip that surge tank right out.
Posted on: 2010/5/24 18:37
'75 1200 B110 - 154hp Race prep A14
'97 Silvia - 600hp SR20 time attack
'07 Hilux - Tow car
« 1 (2)
