« 1 (2)
Re: which is better... CA18det vs 4AGZTE
From south coast nsw
4agte with t50 fits in no tunnel mods =good
ca needs tunnel mods of the shelf mounting kits =good
4a looks better in the engine bay IMO sits way lower!
if the engine you looking at out of a sprinter manifolds they may probably foul on the tower and bonnet.
Posted on: 2010/5/23 8:57
From sydney
Yes you can engineer a car with a top mount turbo
Posted on: 2010/5/23 11:34
From Brisbane
Getting 180-220rw kw out of a 4AGZE (T) is not that hard, many have got much more! And in my opinion they appear to be a stronger engine. They are also smaller and sit lower in the engine bay.
The T50 sprinter box fits the tunnel, but the stronger W series of "supra" boxes need a larger tunnel (and special bell housing). Plus you can make different spec's of engine. i.e. 20 valve silver or black top in turbo/super charged or natural aspirated. Even get a 7A bottom end built to go on the 1600 head (any 4AG head will fit with some mod's), when these are turbo'd the results appear to be astonishing.
The reason I chose this engine, is it's different (dont ask I haven't even started mine). How many CA 1200's are there? Freakin heaps, and with good reason to, it's a bloody effective conversion! For simplicity you cant beat a CA. It has all been done before and there should be no surprises in the conversion.
Either will make you car extremely competent on the streets or strip, just do what you prefer.
Posted on: 2010/5/23 13:46
forget both them motors and put 1 of 2 real motors in SR20 or 13b
Posted on: 2010/5/24 5:15
From Geelong, Vic
lol since when were SRs real motors?
Posted on: 2010/5/24 11:01
I worked at Local Toyota Workshop and will tell you the ANY 4AGE Varient is a brilliant option. Lower Engine for better balance in the front plus very strong internals. you will easily get 250hp out of it with fairly stock internals just open up the head a bit and cam it. Look forward to hearing your Decision..
Posted on: 2010/5/24 11:34
« 1 (2)
