« 1 (2) 3 »
Re: quad throttle body injection
From Southern Highlands, NSW, Australia
Should get a fair bit of change from 3K, just a matter of shopping around.
Posted on: 2010/5/27 6:50
'72 1200 sedan hillclimb/supersprint car
From Melbourne Vic
it really depends on how much you can do yourself. its very easy to blow 3 grand quickly and not have much to show for it.
the computer will cost you anywhere from $500 to say $2500 (can always go higher!) and the throttle bodies themselves are cheap if they come from a bike but theres lots to do to make them fit. don't forget your fuel system pumps surge tank pressure reg...
don't get me wrong its the way to go for smooth power, awesome fuel economy cold starts etc but its no walk in the park there is plenty of work and some $$'s to spend!
Posted on: 2010/5/27 8:34
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
From Sydney
Well i saw kits that are basily a weber carb but arnt a carb and fuel fails and stuff for arount 1k
and i was thinking after you buy gsxr bodies and get a manifold made it would be around the same cost???
Computer
fuel pump and surge tank
injecters
hey whats the roll of the surge tank?
jpg  800-901c_econo_kit_4cyl_dcoe.jpg (7.36 KB)
13160_4bfe317def170.jpg 250X156 px
Posted on: 2010/5/27 9:46
From Rosewood, QLD
that kit looks nice Cracka id like to invest in something like that for the Nav
Posted on: 2010/5/27 10:14
1971 B110 sedan project.
2012 Nissan Micra daily.
From Sydney
Yea and it bolts to your twin carb manifold.
And that is from an Australian supplier.
Posted on: 2010/5/27 11:41
From Rosewood, QLD
haha would have to get a twin carb manifold custom made up for the Nav, can get my hands on an EFI intake manifold from a Z20E just needs injectors and fuel rails and ECU... will end up a frankenstien motor or maybe cheaper to do an engine swap lol
Posted on: 2010/5/27 12:01
From Sydney
yea that makes it harder when you have to start making everything.
although nothing wrong with a frankenstein
Posted on: 2010/5/27 12:07
Basically a surge Tank is a mini fuel Tank... it sits in between the main tank and fuel rail.. normally closer to the tank although that is not important... what it does it provide fuel on hand at all times.. when racing or cornering alot the main pick up can sometimes go without fuel thus making the engine starve of fuel... havin that extra litre or so on hand the secondary pump can always supply fuel to the engine even in the most extreme cornering/racing applications....
jpg  surge.jpg (22.24 KB)
11951_4bfe6dafd961c.jpg 660X307 px
Posted on: 2010/5/27 14:03
From Geelong, Vic
bike throttle bodies can be got for about $150, i bought 2 pairs a couple of years ago for about that
then you have $800 or so to spend on a manifold, cant see it really getting up to a grand if you are doing it yourself
and dont forget that with the dcoe throttles you have to have a webber manifold, and these can cost up to $250 to get
Posted on: 2010/5/27 14:16
From windsor, sydney
Hi guys just to show you some pics of the 1200 gx injection manifolds i have made for the mechanical injection set up , it could easily be made for electronic with the addition of injector bosses and TPS, I have enough bits to put two of these together ,cost about $1600-$1800
jpg  1200 inject 1.JPG (135.74 KB)
9512_4c00f43c243ef.jpg 826X1169 px
Posted on: 2010/5/29 12:02
WARDMAN ENGINEERING
CNC machining
Race Car Fabrication
Suspension, Brake, Drivetrain modification
TIG welding of all metals
0413 595 627
« 1 (2) 3 »
