Flywheel bolts?
From Ballarat Victoria
Im chasing part numbers or parts again.
Im needing 6 flywheel retaining bolts for an early A12 with the imperial threads (3/8 UNF?) Does anyone have some they will sell(or part swap) or can someone help me with part numbers so i can get some from Nissan.
Thanks heaps.
Posted on: 2010/5/31 14:26
Re: Flywheel bolts?
From Freo
hmm, I may have a set in stock, can't remember if i got early, late or both..
remind me...
Posted on: 2010/5/31 14:55
A15 PSI Project Motor
'72 CB750k,
Re: Flywheel bolts?
Pm sent Dundee.
Im still looking, Can someone maybe help with part numbers?
Thanks again.
Posted on: 2010/6/1 12:21
Re: Flywheel bolts?
Ive got a 1200 book will bring it in tomorrow
but most Nissan Parts places can look them up
using your chassis no:
Posted on: 2010/6/1 12:49
Re: Flywheel bolts?
From Perth
12315-18001 is the later A10 bolt... probably the same as early A12
Posted on: 2010/6/1 15:56
Re: Flywheel bolts?
The 1200 ones:
12315-H1001 BOLT-FLY WHEEL 6 A12 MANUAL
The new ones:
12315-H6900 BOLT-FLYWHEEL 6 $4.83 USD
http://datsun1200.com/modules/mediawiki/index.php?title=Crankshaft
Posted on: 2010/6/1 17:01
Re: Flywheel bolts?
Thanks DD and dattoman, I`ll order some tommorow.
Posted on: 2010/6/2 11:45
Re: Flywheel bolts?
From Melbourne, Aus
gday Simon,
If you have any trouble tracking some down I may have some among my collection of A12's. How do I tell if it is an early model?
cheers
Bruce
Posted on: 2010/6/2 23:33
Re: Flywheel bolts?
Bruce, dizzie at the front usually rather than middle of block.
Posted on: 2010/6/3 0:28
Re: Flywheel bolts?
From Melbourne, Aus
The A12's I have, have the dizzie in the middle.
The A12 that you got off me D, may have the correct bolts that Simon is looking for then?
Posted on: 2010/6/3 2:42
