(1) 2 3 4 »
is there any suspension upgrades for 1000's?
From Adelaide, Australia
hey guys i have a 1000 ute and it handles like a boat. is there anything i can do to help this?
Posted on: 2010/6/2 9:31
Re: is there any suspension upgrades for 1000's?
Love to know myself as mine could also be better!
You could shim the upper control arms for some camber.
Be interested if anyone has ever reset or "retuned" the transverse leaf spring, and how much difference that would make.
Mines a bit worse still scince I wound the radius rods right out to eliminate the scrubbing :/
Posted on: 2010/6/2 9:51
From Perth
New bushes should see it handling like a gokart
Mine do
Changing the spring will only play around with your height ... making it stiffer will make the handling worse... they are bumpy enough as it is
Though I do have gas shocks in mine which have stiffer setup than the oily's
Dial some neg camber into it and get the radial rods screwed right in (after clearancing for tyres) and it should track alot better
Posted on: 2010/6/2 11:25
From Melbourne Vic
which bushes are you talking about, i don't think they make some bushes any more :(
Posted on: 2010/6/2 12:02
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
From Sydney NSW
Did I just see datsun 1000's and new bushes in the same topic?..
Posted on: 2010/6/2 12:46
From Perth
I bought all new ones from Nissan a couple of years ago
However some people here have replaced them with Urethane
But aren't forthcoming with the part numbers
Posted on: 2010/6/2 13:03
From Perth WA AUS
Repco will match them for you if there is a suitable nolothane part to match.
Posted on: 2010/6/2 13:21
Datsun 1200 2Dr sedan.
From mandurah
maybe you could just buy a 1200 and go coil overs :) jokes ,i like thous but they might be a little small and its too hard to pu a CA in and there is a guy in perth that does mounted rubber and can make bushes and you can choose the complound of the rubber ,maybe look into getting bushes made ?
Posted on: 2010/6/2 13:40
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Sydney NSW
Thats funny cos when I called nolathane up they didn't give a #OOPS#, said they wouldn't match up any bushes for me. I think it may be those stinkers red ranger with their monopoly. Will definately give repco a try cheers
Posted on: 2010/6/2 13:45
From Freo
i've posted the numbers b4..
the rears are same as 1200,
radius rods, are same too, I think, but 1600 might be same..
Posted on: 2010/6/2 14:23
A15 PSI Project Motor
'72 CB750k,
(1) 2 3 4 »
