« 1 (2) 3 »
Re: Finally! an engine setup i am sticking with permanently.
From mandurah
aaawwww that CA looks sexy as with those carbys ,what hp would a CA make with carbys ?
it could be a good upgrade on my A14 !
Posted on: 2010/6/6 13:36
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From ACT Aus
very interested to see how it turns out, keep us posted
Posted on: 2010/6/6 14:38
unfamilia wrote:
You have bump stops? Your soft
From Midway City, California
funny thing about that, gov'na can say what he wants, dont need smog anymore, and i havent met a cop that knows what engines datsuns came with. i could tell them its stock and pull it off
Posted on: 2010/6/6 21:44
if it was easy to restore, they would call it chevrolet
don't piss off America, or we will bring democracy to your country
well i dont know how you would go about timing it cos you would need to sort out the ignition as the CA has a computer to do all the work and you could try to adapt a dizzy to it or run a crank angle sensor and then run that to a module or something to do the rest of the work for you
lets pretend ZigZag doesnt know what you are talking about.
say it again, for his sake
Posted on: 2010/6/6 22:14
From Geelong, Vic
wouldnt quad throttle injection be the better way to go? would probably be just as much time and money involved. but you would have efi tuneablility economy and power with that carby induction noise
would also look neater as you could keep the stock ignition setup rather than having to fit a dizzy in then have leads going all over the place
Posted on: 2010/6/7 1:13
I think from memory that Tomei make such a system for the CA18... Anything regarding a naturally aspirated nissan engine i would look at Tomei first and then Nismo.
Revs to about 10,000rpm with ITB injection- the works. Made around 250hp or so at the flywheel.
Posted on: 2010/6/7 3:13
could i run the ecu to control the timing?
Posted on: 2010/6/7 14:23
From mandurah
ok zigzag listen very carefully ,now if you take the injection of the motor and try to run carbys on it you will need to put a dizzy on it instead or a CAS (crank angle sensor) and this will fill the place of the computer telling the coils when to spark
i want a carbyed CA for my ute ,hhmmm ive got a spare CA and a set of GX carbys of an L series i might have a fiddle with them
Posted on: 2010/6/7 14:33
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
what would be required in getting that to work?Quote:
Posted on: 2010/6/7 14:37
why would u wanna go carbie?
Posted on: 2010/6/7 23:03
1200 ute unfinish'd sr20 $$$
1200 ute stocko
bumble bee drift pig
XR8 tow car / daily
bailz is orsum
« 1 (2) 3 »
