AUDI 50 CLUTCH INTO 63A GEARBOX??
From Lisboa-Portugal
I found that the clutch from Audi 50 between 74 and 78 has the same dimensions and number of splines than the b210 63A gearbox. Could this fit into my gearbox?
Posted on: 2010/6/14 15:12
Re: AUDI 50 CLUTCH INTO 63A GEARBOX??
From Albany, Perth Australia
that would depend if it will fit in the bell housing
Posted on: 2010/6/14 15:20
1200 Smerf Mobile
It measures 180mm and it got 24 splines
Posted on: 2010/6/14 15:26
What is the diameter of the input shaft?
What is the thickness of the disc?
Posted on: 2010/6/14 17:32
The diameter of the imput shaft is 20.5 mm the thickness i have to ask! This clutch also came in early VW Jettas and Golfs and some Austins too. I will confirm the thickness.
Posted on: 2010/6/14 17:45
63A clutch parts at rockauto.com
24T clutch kit $77 USD (disc, released bearing, cover/plate, pilot bushing and alignment tool)
Or just get the disc from Nissan part number 30100-K0500
Centerforce sells them too.
Posted on: 2010/6/15 0:07
From Perth
The question of course is ... why ?
Chances of the pressure plate bolting to the flywheel are very very remote
Posted on: 2010/6/15 0:25
you can use the standard A14 cover. The disc doesn't care, as long as it is the correct thickness.
But the AUDI clutch spline input shaft diameter is different, so that won't work.
Posted on: 2010/6/15 0:28
its possible, if Im not wrong an early toyota clutch from will
fit some of the 260z gearboxes but its a smaller diameter yet
same input spline.
Posted on: 2010/6/15 1:08
I found one cheaper and more available, the 140j violet(j710) clutch.
Posted on: 2010/6/15 10:02
