« 1 (2) 3 »
Re: looking for cheap ones of these in melbourne
went to bunnings, got a heap of them and only 1 t peice, and 10 hose clamps for under $40. bargain.
just have to grind the threading off them and they are same as the $30 one from the auto shop. same casting marks too! surely must cost more to thread them then cast them without.
Posted on: 2010/6/29 12:35
From Perth WA AUS
Good work dude!
Posted on: 2010/6/29 12:40
Datsun 1200 2Dr sedan.
Uh oh, Bunnings hose clamps...
Posted on: 2010/6/29 12:46
nah got the good hose clamps not the cruddy 10 for $2 ones.
just went out and had a play- will get away with 1 t piece and maybe 1 or 2 90 deg bends, depends how forgiving the hose will bend once heater is back in.
Posted on: 2010/6/29 13:59
From Albany, Perth Australia
there should be a place called purple pig they have all those types of fittings. Pirtek should have some 2. I dont know if you have 1 there but all those fittings come from tubefit here in perth. Hope that helps
Posted on: 2010/6/29 15:30
1200 Smerf Mobile
does any one have handy the id of the heater core hose? is it 12 mm or 16mm?
cant remember off the top of my head.
Posted on: 2010/6/30 0:17
The Datsun 1200 heater hose is specified as 1/2 inch inside diameter. What is the metric equivalent for that?
Oh -- and it is special thin-wall hose.
Posted on: 2010/6/30 1:08
From Geelong, Vic
couldnt find any plastic bends mik?
Posted on: 2010/6/30 2:00
did find plastic bends but not suitable for hot liquids.
Might try some 1/2 hose as there are heaps of fittings for 1/2 inch and 3/8 available- even brass air compressor fittings for $3 each suitable for hot liquids.
5/8 is a pain of a size.
Posted on: 2010/6/30 3:16
I use 1/2" copper pipe fittings for 90-degree bends. Cheap as -- also they come in 5/8 size too.
The 'reducing' style is 5/8 outside diameter on one end.
Posted on: 2010/6/30 13:49
« 1 (2) 3 »
