« 1 2 (3) 4 5 6 7 »
Re: fitting trx rear brakes on 1000 front end. can this work?
i see thanks for the clarification, the title funnily enough says trx rear on 1000 fronts! :))
Nick I think the r31 setup is not as good for clearing the tie rods, Ive looked at it in the past
but you are right in suggesting so, I have them on the rear of my h145 now.
Alloy backing plate oohhh yummie :)
Posted on: 2010/7/22 1:30
From Wagga Wagga, NSW
I meant that will SERIES 3 BLUEBIRD and BLUEBIRD TRX rear brake setups be the same, as the series 3 bluebird is much more common then the trx
Posted on: 2010/7/22 3:17
Ryan(Zigzag) says:
mmmmm men
Jake(tuf-110) says:
i thought you might say that
Ryan(Zigzag) says:
its raining men
Jake(tuf-110) says:
oh its your day
From Ringwood, Melbourne, AUS
pls let me know which hub your are using as 1200 coupe hubs are rare now.
Guess they aren't too rare in NZ.. by the time postage is accounted for prob not worth it though..
http://www.trademe.co.nz/Browse/Listing.aspx?id=304272008
Posted on: 2010/7/22 3:22
Deano
NZ is jdm heaven along with the west indies
Posted on: 2010/7/22 5:31
whats going to hold the rotor from wobbling?
Posted on: 2010/7/23 23:29
the wheel being tightened on, thats how a few discs are held on i am aware
Posted on: 2010/7/24 0:50
Ryan(Zigzag) says:
mmmmm men
Jake(tuf-110) says:
Ryan(Zigzag) says:
its raining men
Jake(tuf-110) says:
oh its your day
From pooraka,,adelaide
yes this setup does work i kno of some one who has done it but round here u dont c as many s3 bluebirds around as sigmas but also some s2 bluebirds did come out with these disk brakes on the rear as an option but only on an 8bolt diff not a 10 but should still fit
Posted on: 2010/7/24 1:54
620 ute -sr20det full irs
vanette-a15 turb
260c- daily
1000 4dr- a15
1000 4dr- project to be sr20
garage 910
From Adelaide, Australia
bout time andy :P
Posted on: 2010/7/27 2:38
parts needed: GX air filter box. for sale, stanza steering wheel, 1000 gloveboxes lids
so the disc rotor centre sits snuggly over the hub snout?
Posted on: 2010/7/27 4:06
From Geelong, Vic
D why is r31 not as good for clearing the tie rods?
Posted on: 2010/7/27 9:08
« 1 2 (3) 4 5 6 7 »
