« 1 ... 1574 1575 1576 (1577) 1578 1579 1580 ... 1777 »
Re: PERTH BOYS.. GO THE DATTO
jesse cheers for the inner rails off that sedan, i wanna grab the chassis rails and possibly the front inner sills and a bit of the floor. next time ngel and levey are headed down there
Posted on: 2010/7/31 7:48
From mandurah
yeah i found my grinder disks so i can cut the floor/sill pieces out if you txt me the meassurements
i will start emptying the sedan and ill flip it over if i have time today ,then the rails will be a piece of piss to cut out
Posted on: 2010/7/31 8:31
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
i was thinking more the whole floor well up to behind the front seats, would take a bit less effort and just cut it off the firewall and tunnel. i will cut it out next time i am there as long as thats ok with u. i dun wanna cut the car in half if its going to be a pain for you
Posted on: 2010/7/31 9:53
From Perth
Do you even have a Datsun or are you just building one from parts of others ?
Posted on: 2010/7/31 11:11
From Albany, Perth Australia
you rang jesse...tried calling back but your phone is off or no reception
Posted on: 2010/7/31 11:26
1200 Smerf Mobile
I am building a commodore I just need the Datto for parts. What are you building?... Or do you just come on here and talk the Datto talk but don't walk the walk?
Posted on: 2010/7/31 13:23
From Perth WA AUS
Not too much rust in that sedan hey Bailz, good to see the bits are going to a good home and not to sims.
Posted on: 2010/7/31 13:27
Datsun 1200 2Dr sedan.
Yeh I feel bad cutting it up but seeing as the roof is off it, may aswell get the floor pans out before they go rusty too
Posted on: 2010/7/31 13:42
From mandurah
nah bailz its yours for the raping haha ,you can take what ever you want out of it ,and i started emptying it today ,but then i decided to finish my fuel lines and run my fuel pump wires and i just need some condute tubing to make it less likely to rub through the wire and short out :(
brett ,do you have any RC car stuff left ,cos im fixing my team losi mini-T and i just need new wheels and a steering servo ,and motor ,hmm i used to think they were expensive ,but i have since discovered the datsun and now i have realised how cheap it was to run my old RC cars
Posted on: 2010/7/31 13:55
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
nah i dont have anything left of my rc cars.....but if you have any sills left i say cut them out for me...cause you never know when you might need em
Posted on: 2010/7/31 13:57
1200 Smerf Mobile
