rev counter wiring
From Vanderbijlpark, South Africa
last night i installed my gx's original rev counter into the ute. anyone know how the wiring hooks up and maybe have any pics? will it be a problem since the ute did not have a rev counter? the dash is out of a 2003 model (the grey dash) any help would be much appreciated
Posted on: 2010/8/4 9:56
93' Nissan 1400 a15 60a (daily)
82' Datsun 1400 ute (sold)
73' Datsun 1200gx Coupe (sold)
Re: rev counter wiring
From mandurah
ok there will be about 4 wires and they should be labels an the back of the gauge
for mine i ran + to the + side of the coil and - to earth
as for the other 2 ,one of them will be for the park lights and the other for the rev signal , the rev signal will go to the negative side on the coil ,running the park light is optional ,but is good for hooning at night time :D ,this can just be run to the park light feed on the fuze box
Posted on: 2010/8/4 10:04
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
mine has 2 wires and a small screw which i think must be hooked up to a wire as well, it's got the little fork wire wich is black and the other one is yellow with around lug on it
Posted on: 2010/8/4 10:14
From Sydney, Australia
sounds like a normal 1200 tacho, that may connect to wires taped to your loom. As it was likely an option even on the 2003 utes.
Otherwise you'll need to refer to the 1200 wiring diagram that shows that the tach loop just sits in line with the ignition wire to the coil. If you wire it backwards the tacho needle will go in the wrong direction. Find a diagram. 2003 model Utes are a ZA specialty
Posted on: 2010/8/4 10:57
A 1200 GX tacho is wired differently from a late model 1200 ute tacho.
Posted on: 2010/8/5 4:36
can you maybe expain more about the different wiring? would really like to use the gx tacho instead of these multi color oversized tacho's
Posted on: 2010/8/5 6:56
1970-1973 Datsun 1200 (including GX) has tachometer wiring in the wiring harness. The tachometer runs off the coil + signal. It is a series induction wiring.
Most other tachometers, including Datsuns and other brands, run off the coil - signal. It is a parallel wiring.
Posted on: 2010/8/5 7:15
