« 1 (2) 3 »
Re: A10 or A12?
Early A12 re-stamped + later A12 gearbox. Pic of other side of engine and a close-up of the number to confirm.
Posted on: 2010/8/5 9:24
Re: A10 or A12?
From Brisbane
Pic of eng # in a few min ...
Posted on: 2010/8/5 9:38
Re: A10 or A12?
From Brisbane
ok here ladies ...
Would the grind and re number be done for ease of registration?
If it is in fact an A12 then would it need a Mod Plate?
Posted on: 2010/8/5 9:41
Re: A10 or A12?
From Ringwood, Melbourne, AUS
You can see in the pic of the carby side that it has a block ventilation pipe, so going from the other Thou/A10 experts opinions in earlier poasts, it would seem it is a restamped early A12.
Posted on: 2010/8/5 10:19
Deano
Re: A10 or A12?
Typical toolbox letter punch font.
There is a way to get it (font & Numbers) perfect but leave that for another discussion.
Basically the font is wrong, the font size is too big, numbers all over the place.
Here is what a stock casting sequence should look like, neat crisp and perfectly straight:
jpg  IMGP0344.jpg (87.17 KB)
7952_4c5a83beb4d0a.jpg 1191X592 px
Posted on: 2010/8/5 10:26
Re: A10 or A12?
From Coondle, WA Australia
if it is in fact a restamped A12, but it matches the compliance plate, and your rego papers, then as far as the law is concerned and any insurance company then no you need to do nothing.
Also, Im pretty sure that you can infact install an A12 into a 1000 without getting it engineered. it just needs an engine number change done. at least here in WA it is.
Its odd that someone would restamp the engine, unless they wanted to convince a potential buyer that it was all original and therefore worth more. I dont believe that it really applies to the datsun market significantly (unlike the falcon and monaro nuts). I would be impressed by an all original thou, but would struggle to pay much more compared to a non- original engine model.
Personally, I wouldnt bother. It looks neat and tidy in there, an as long as everything is legit on the papers, just run with it.
Posted on: 2010/8/5 11:07
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
Re: A10 or A12?
From Brisbane
Thanks fellas ...
As far as i know its all ok :)
Maybe one day an A15 :) but for now its all good :)
Hamza
Posted on: 2010/8/5 11:58
Re: A10 or A12?
From Canada, B.C , Richmond
I've got a A15 in mine... it makes transmissions explode.
Posted on: 2010/8/5 21:31
Re: A10 or A12?
From Brisbane
lol, ok ill forget the A15 idea ...
Posted on: 2010/8/5 23:58
Re: A10 or A12?
The timing cover is also a 1972 A12 type. Datsun 1000 engines used the early type used by the first A12s.
Wow, a Datsun 1000 with matching-numbers A12. That is worth something.
Posted on: 2010/8/6 2:29
« 1 (2) 3 »
