« 1 (2) 3 »
Re: why Need To Replace Spark Plugs Regulary ?
From Brisbane
if you have a fairly basic engine, in good condition and in a good state of tune, you'll get ten years out of sparkplugs.
Posted on: 2010/8/25 13:35
From Sydney, Australia
and if you get platinum plugs you only replace them every 100,000 kms on a healthy engine.
Regular (quality) servicing gives you improved reliability, which means less breakdowns on the side of the road.
Posted on: 2010/8/25 22:24
From Sri Lanka
Hi Guys
Pulled all the Plugs yesterday back and checked only one plug was bit black like the pic here all the other plugs were ash mixed white color and were very clean
thanks
Regards
sumith
jpg  spark_plug_Bad.JPG (12.18 KB)
10994_4c75e4b1e54eb.jpg 350X350 px
Posted on: 2010/8/26 4:52
Yes, the plug is fouled. It's not a bad plug, but something is wrong with the engine. It will foul the next plug you fit.
Now your task is to find the cause and repair it.
Posted on: 2010/8/26 5:18
From Brisbane, Australia
#4 seems to cop the PCV fallout I've found. . . a little darker but nothing extreme.
Are you having any issues with the float level?
If fuel is pooling, it usually end up in #4 too. . .
Posted on: 2010/8/26 6:35
From Melbourne AUS
be careful removing and replacing spark plug leads while the engine is running.
a good spark will jump a fair distance, and they bite really hard!
Posted on: 2010/8/26 6:46
1973 B110 A12
From Sri Lanka
Hi Guys
thanks for advices, at the moment i am using NGK BKR5E in my 1200, but this is not the correct plug for it . i think it is BPR4ES.will that be this issue , i don't think so,
Thanks
regards
sumith
Posted on: 2010/8/26 10:41
ANGE wrote: be careful removing and replacing spark plug leads while the engine is running. a good spark will jump a fair distance, and they bite really hard!
YEAH! I got grilled by my Scorcher ignition on high idle a few weeks back WOW that was pretty startling!
Posted on: 2010/8/26 10:48
From Sri Lanka
Hi Guys
i also had few times
Ha ha you call it a JUMP START
thanks
Regards
sumith
Posted on: 2010/8/26 11:43
NGK BPR5 is a correct plug -- See Spark plugs.
NGK BKR5 is I don't know what it is
It is not causing the problem, or all the BKR5E plugs would be fouled. Unless you are using other plugs in the other three cylinders...
Posted on: 2010/8/27 3:00
« 1 (2) 3 »
