A12 ARP bolt kit vs A14 ARP kit
From South Africa, Bloemfontein
Hi
I am posting on behalf of Clive.
He bought a ARP stud (for the cylinder head bolt down) and ARP conrod kit and they were listed for A12 engine.
He is going to use it on a A14/A15 engine.
Will it work?
Posted on: 2010/6/4 6:22
1977 Datsun 1200GX
Re: A12 ARP bolt kit vs A14 ARP kit
Already discussed several times this year
ARP Brand connecting rod stud set
* 102-6002
The same rod studs are used by all A-series engines, from A12 to A15.
http://datsun1200.com/modules/mediawi ... le=Engine_block#Rod_Studs
Posted on: 2010/6/4 8:06
From Freo
old post drag up.. he's asking about Head studs.. not rod bolts DD..
Posted on: 2010/9/2 11:18
A15 PSI Project Motor
'72 CB750k,
He needs to be carefull about which A12 is being refered to.
Since the cylinder head stud kit that he bought seems to be listed for the A12 & not "All A series except 1966-'73 A10 & A12" I would assume that it is for the earlier engine.
The later engines [mid mounted distributor] [1974 --> A12, A12A, A13, A14, A15] have one bolt that is longer than the others, so I would expect the ARP stud kit for these engines to also have one stud that is longer.
The earlier engines [forward mounted distributor types] have ten head bolts that are the same length as each other so I would expect that the stud kit would also follow this pattern.
Posted on: 2010/9/3 16:46
Love your Datsun.
Treat it well.
This might help: ARP
Posted on: 2010/9/4 3:41
