Aspirated SR20
From Bridgetown, Barbados. W.I
got a sr20 2day. it has almost everything except the distributor, wireharness and ecu.
Anyway since i dont have things, jus wondering how much power(hp & lb ft) can be created from this engine using 45mm' webers.
What tricks or work (headwork) could be done to obtain the max from this engine?
thanks.
Posted on: 2003/12/23 1:28
Life's better SIDEWAYS!!
Re: Aspirated SR20
From Sydney, Australia
If you were using the injection, you'd be able to get about 100kW at the wheels with the standard engine.
You may be able to get similar figures with webers, but you'll lose low revs drivability.
Just put a decent 2.5 inch exhaust and free flowing header, and you'll be doing fine.
I'd recommend that you try and get the electrical bits required to use injection. Otherwise you will have a lot of trouble finding the information on how to tune the SR20DE to it's best using webers.
Chris.
Posted on: 2003/12/23 1:34
Re: Aspirated SR20
thanks.
will try to do that but how much hp is 100kw?
thanks.
p.s. a ratio would be good for futher reference.
Posted on: 2003/12/23 2:02
Re: Aspirated SR20
yeah by the way...does anyone make full race cams for sr20de engines.
I would like to modify this engine fully what else can be done.
all tips & tricks welcomed.
thanks.
Posted on: 2003/12/23 2:09
Re: Aspirated SR20
From Melbourne, Australia
15kw = 20hp
so its 133hp
Posted on: 2003/12/23 2:13
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: Aspirated SR20
From Okinawa, Japan
There are plenty of full race cams out there and webers would be so awesome because not many people do them up like that. Here in Japan Tomei, JUN, HKS, and Greddy are just a few names that make cams. Tomei even makes a race prepped NA SR crate engine.
Posted on: 2003/12/23 2:16
Re: Aspirated SR20
133hp . this model sr20 is the one from out of the bluebirds and other front wheel drive cars, with the plain vavle cover. It also has multi-point injection.
p.s. is there any differences between a newer sr20de and the old one. i.e. stroke & bore. If there is no difference how comes the newer sr20's make more power than the new ones.
Posted on: 2003/12/24 3:23
Re: Aspirated SR20
another problem.....thinking of putting this engine in a B310 sunny..but the thing is the throttle housing is going to face the firewall (since the engine came from a fwd car) is this a problem. Or could u jus get a hose with a bend and bring the air hose to the filter at the front.
thanks.
Posted on: 2003/12/24 3:25
Re: Aspirated SR20
From Okinawa, Japan
FWD and RWD SR20s are different blocks and aren't compatable to swap to oppisite configurations from what people here in Japan (that have tried it) tell me.
Posted on: 2003/12/24 3:31
Re: Aspirated SR20
From Victoria
746 watts in one HP
Posted on: 2003/12/24 12:54
