wtb: adjustable lca's (1200)
From Melbourne AUS
hi just seeing if anyone has some lying around they wish to sell, before i bother cutting mine up.
happy to pay post
cheers
Posted on: 2010/9/8 11:03
1973 B110 A12
Re: wtb: adjustable lca's (1200)
try 1200rc ange
Posted on: 2010/9/8 11:06
Car free
getting serious- maddat ones?
Posted on: 2010/9/8 12:03
From Melbourne AUS
only half serious, i spun my camber tops to gain castor but lost probably .5deg of neg camber. so i thought... why not
maddat are always an option, just thought id see whats out there if anything...
Posted on: 2010/9/8 12:11
1973 B110 A12
From Ringwood, Melbourne, AUS
Are you going full rose joint or still bushed?
Posted on: 2010/9/8 12:22
Deano
From Melbourne AUS
bushed will be fine for me
Posted on: 2010/9/8 12:24
1973 B110 A12
From Western Australia
what ball joints are you using?
the early type with 8mm bolts (12mm head)
or the late type with 10mm bolts (14 or 17mm head)
If you are using the late ones swapping to stanza ball joints will give you more track, roughly 12mm per side resulting in more negative camber.
Posted on: 2010/9/8 18:48
1200 Sedan SR17VE + TURBO (Borg Warner twin scroll), 6 Speed, Brembos, Autronic SM4 ...coming together slowly.
Stanza rally car mostly ex works = FIA head, 50mm Mikunis, option one, works diff, 4 pot FIA calipers and vented disc all round, enkies, h...
From Geelong, Vic
and if you have stanza ball joints already then i have a set of 1600 steering arms that will push the track out further, or 200b ones do the same but have a slightly different ball joint taper
Posted on: 2010/9/9 8:09
From Melbourne AUS
mine are 10mm thread 14mm head.
but i dont know that theyre the same as stanza becuase im using a 120y strut and im pretty sure the bolt spacing is different at the bottom of the strut leg.
anyhow, rather than fiddle around with ball joints, adjustable lca's will allow me to easily increase/decrease neg camber for track/street.
thanks for the tip anyway
1973 B110 A12
From Geelong, Vic
can still use the stanza balljoints if you dont have them, but the steering arm idea is out
could just make lengthened control arms if you know where you want to set them too, then its kinda legal. more legal than adjustable ones anyway
Posted on: 2010/9/9 8:13
