« 1 (2)
Re: L20b into a Datsun 1200..
From Brisbane, Australia
Remove engine mounts from L Series X Members and weld into 1200 member to fit the engine low and far back as possible ?
I used the saddles from the Stanza x-member because it was just the easiest way to get suitable brackets in there for the L series mounts. To get the engine as low and rearward as possile requires mods to the mounting brackets on the engine and careful positioning of the saddles on the x-member.
Secondaly... can the same be done for the gearbox member ? or will i need to fabricate one myself ?
I have removed the gearbox mounting bracket on the drivers side of the tunnel for clearance, and so I could fit the reverse light switch. I have a manual tunnel which is smaller than the auto tunnel. You have to fabricate a gearbox x-member with different body attachment points if you have a manual tunnel. You may be able to use the factory mounts on the body if you have an auto tunnel.
Which gearbox would go in the easist ? no point doing things the hard way :)
Any of the Short boxes. Stanza 5spd or Stumpy Skyline boxes are definitely an easier fit than the long boxes, but the long boxes can be used as well.
How do the inlet manifold clear the strut towers ? close fit ?
http://datsun1200.com/modules/myalbum/photo.php?lid=1143
Custom tailshaft that mates up from the gb to diff ?
yes? You'll be using a larger splined L series gearbox output shaft, which is also further back in the body, and will have to mate to whatever diff you use that will also have a longer head than the standard one. You'll either have to modify some factoy tailshaft at both ends and have it rebalanced, so you may as well just have a new one made.
And do you have a picture of this Drag Link ?
http://datsun1200.com/modules/myalbum/photo.php?lid=1152
drag link is the steering link that connects both side of the car, running behind the x-member on 1200s. As you turn the wheel, this bar rises due to the geomtry of the pitman and idler arms. Mine clears the sump by only a few mm at full lock
Posted on: 2003/12/22 23:47
From Mandurah WA
It may be easier to get a auto then ?
I already have a 4sp a series box and clutch i could put in before i do the swap.
So you could not fit the reverse light switch in there because off the mounts ?
Is there a way you could have another type or reverse light switch ?
So far things sound tempting ;)
Off topic, Datsun Stanza's how much they weigh ?
Posted on: 2003/12/23 12:21
1984 Mazda 626 stocker..
Soon to be 32/36 weber powered
marginally. if you already have a manual body, I'd use that. auto tunnel would make life a bit easier, but certainly is not a necessity. you could cut and weld an auto tunnel in. It would make a gearbox change easier later on - my engine almost has to come out to get the box out.
that's right.
yes. initially, when I got the car engineered and registered, I still had both the mounting brackets still in the tunnel. The reverse light switch mounted on a simple bracket under the console activated by the shifter itself.
Posted on: 2003/12/24 2:47
From Mandurah WA
So given if i use another type of reverse light i still have to make a custom gearbox member ?
Posted on: 2003/12/26 9:35
From Arlington, TX, USA
1200rallycar wrote:
im guessing you mean 120y for us
not sunny as it has coil rears
Well, I did mean B310, but a 120Y would work just as good.
We've used coil-sprung rear diffs in a few 1200s here. We just cut off the stock mounts and weld on mounts for the leaf springs.
Posted on: 2003/12/27 3:12
1973 Datsun B110 Coupe (A15/5spd)
1977 Datsun 280Zed (5.0L/5spd)
Posted on: 2004/1/10 8:02
From California
Amazing how impressive the ubiquitous L-series looks when shoehorned in a 1200!
Posted on: 2004/1/10 17:36
« 1 (2)
