jap stretching
From port elliot , SA
these blokes have got this down to a fine art hahah i love stretch
http://www.youtube.com/watch?v=8xx2e6R4jY4&feature=player_embedded
Posted on: 2010/9/22 11:55
Re: jap stretching
From Brisbane
are we looking at the tyre or the stretch on that dudes permed "elvis" fringe?
how well/badly do stretched tyres perform? is there a cut off point?
Posted on: 2010/9/23 4:46
84 1200 ute 4agze, 10psi
Re: jap stretching
It's not about performance, it is about looks.
The tires manufacturer say for best performance, use a certain range of wheel width. Stretching is about putting the tire on a wider wheel than the tire manufacturer specifies.
The tires on my ute are stretched. With flipped leafs and almost no suspension travel. Looks good, but does not handle great.
Posted on: 2010/9/23 5:13
Re: jap stretching
the elvisextreme takes him 6 hours a day of compressor spray and 5 litres
of hairspray so the tire is easy in comparison.
Posted on: 2010/9/23 5:17
Re: jap stretching
Bus stop shelter fringe.
Nice technique.
Posted on: 2010/9/23 5:46
Re: jap stretching
From BlueMountains NSW
OHHh to have that much hair again....only saviong grace now when i tell the girls to vac up the hair in bath room I know it not mine
Posted on: 2010/9/23 15:18
I DON'T LIVE IN THE PAST....I JUST TAKE DAY TRIPS
Re: jap stretching
From Wagga Wagga, NSW
Basically its for hardparking, you wouldnt slide on that stretch basically the bead would come off the rim and rim would meet asphalt, not cool.
Posted on: 2010/9/23 15:30
Ryan(Zigzag) says:
mmmmm men
Jake(tuf-110) says:
i thought you might say that
Ryan(Zigzag) says:
its raining men
Jake(tuf-110) says:
oh its your day
Re: jap stretching
the strech orginally was used in early racing in japan, if you look at early F1 pics you can see the side walls of there cars lean out alittle... nothing to that extream but none the less thats where it comes from. this was replicated by the kuysha and zokusha communitiys (grand champion style) as they copyed the early Gr5 racing style etc... streaching the tyre actually gives a high profile tyre a stiffer side wall making it feel alot better than on a 'standard' sized rim for the tyre.
these days streach is used more for looks/asthetics. it helps alot in fitting oversized rims into undersized guards :P
i personally drift on 15x10's with 205/55 & 50's and its great! i have had a tyre come off the bead at QR mid corner around turn 2 but to my defence, the tyre had delaminated and its a bumpy corner.
Posted on: 2010/9/23 23:20
Re: jap stretching
From North Coast NSW
thats crazy, nice technique tho
Posted on: 2010/9/24 3:17
in need of 1200 coupe parts!
Re: jap stretching
From Forsby Finland
Love those rims/wheels, where could I find a set??
Posted on: 2010/9/24 13:56
I am building a mean Datsun E10 racer , a15 turbocharged engine, aiming for 280hp....
