Browsing this Thread:
2 Anonymous Users
Re: 120y sedan SR20de.... Im now in control... i think.... |
From RAdelaide
Thanks for the encouragement guys. Just waiting to finally crack and buy a tomei oil block so I can plan oil cooler set up. Was thinking of setting up bozuku style external cooler and neat 2nd one behind grill. Have some awesome jiffytite fittings I can use that quick release....
Hmmmmmmm ( see sig )
Posted on: 2010/9/30 12:43
"My mind is a raging torrent, flooded with rivulets of thought, cascading into a waterfall of creative alternatives." - Hedley Lamarr, Blazing Saddles
From Cape Town, South Africa
Any findings on relocating the wiper motor?
Posted on: 2010/10/1 8:45
From RAdelaide
Ok so got a bit done today. After a couple of thousand measurements and cutting once i fitted wiper motor on the inside of the cabin. Relatively easy actually.Glove box requires no mods and dash fascia covers all evidence.
Finished of trans tunnel with stitch weld then grinded back smooth and laid a bead of sikaflex around the seam.
Being that everything was going along well I drilled out spot weld for handbrake reinforcement and relocated it further back to go with new console set up.
Took out oem radio and gave it a good clean, came up awesome! also found a place in the US that ads new inners and a usb cable! So Millennium Falcon!
heres pics
Posted on: 2010/10/2 12:18
did you do the silvia wiper motor replace ment at the same time? perfect opportunity like the b110's and b10
Posted on: 2010/10/3 11:12
From RAdelaide
Ok no, but, would I be doing this for motor life/ replacement later or multiple speed? I've had a think maybe I could use this motor with head light style multi position pull switch for different speeds? Forgive me if I've been on the moon.
Posted on: 2010/10/3 11:51
From Adelaide
looking good K ... I need to get up for a look soon!
Posted on: 2010/10/4 13:09
From RAdelaide
Had lots of time organising and reorganising. Built plate for relays fuses and computer just working on how to mount to firewall, working on heater lines from Nissan to datsun. Radiator is driving me crazy! Sizing and looks keep delaying my decision. Got all lines done for oil cooler. Spent a lot of time on pedal box for tilton set up to find it will not pass engineering being that no balance allowed in street reg'd car. So it may or may not find it's way in later.
Tried a couple of different seats but none so far are a hit. Think I'll reupholster oem seat in prince skyline style theme.
Anywho pics to follow
Posted on: 2010/10/28 12:09
From RAdelaide
2nd time round idea, first i had the whole panel as one and planned to mount it on the firewall, didnt really like the look. Rehashed the idea, this way cable is perfect length for computer to sit under the seat out of the way. Just have to finish making bottom plate to mount it on.
Diagnostic plugs sits neatly in opening, just had to make one for the loom to go through
Also managed to get one Excellent GX badge, something tells me im pushing poo up hill finding another!
Radiator will hopefully be ready this week, getting anci to pull it back on the roto so i can paint the underside
Posted on: 2010/10/31 9:21
From Adelaide
I can't believe the progress on this thing. Will be hard to have to pull it apart again to lay some jam on it. Maybe leave the body as is? hehe
Posted on: 2010/11/7 6:59
Re: 120y sedan and wagon......Im outta control! |
Quite a regular
From hilo hawaii (the BIG island)
where can i get this visor?
Posted on: 2010/11/7 18:18
