60A reverse switch ??? - Update
From Seattle ,WA.
has anyone come up with anything better then the posted idea's in the Wiki for dealing with the Rev switch when retrofitting a 60a 5 spd.into a coupe?
cutting a hole seems like the best but it looks like its part of the trans mount bracket that gets the chop, not sure if thats such a good idea. It'd be nice to finds another switch that threads into the same hole but shorter - any one tried that?
If I could do a micro switch attached to the trans & the shifter engaged it that might be OK as well.
I'm just looking for fresh idea's that are a bit cleaner, probably wont find them but thought I'd ask.
Thanks, Evan
Posted on: 2010/11/22 5:08
Edited by edp on 2010/11/23 4:36:41
Re: 60A reverse switch ???
From Beautiful Sunny (sic) Melbourne
You'll never fit another switch in without modifying the tunnel. I cut the switch off leaving only about 3 mm of protrusion out of the side of the gearbox - it just cleared in the tunnel.
You could put a switch with a little pilot light on the dash, that's an easy solution. One asdvantage of doing that is that you can flash at people behind you who are annoying you
Posted on: 2010/11/22 6:41
From Sydney
I was lucky enough to have an auto trans tunnel in my sedan, so fitting the factory reverse swith worked out OK. I would either make a hole in your tunnel to accommodate the switch or make up a 90 degree fitting that has an internal pin and spring, with a recess in the the pin to ressemble the recess in the selector shaft. can't be to hard.
Posted on: 2010/11/22 8:07
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From Perth WA AUS
Here"s what I did and it works well:
jpg  60a Reverse switch.JPG (162.12 KB)
9665_4cea3fb22f91d.jpg 980X735 px
Posted on: 2010/11/22 10:03
Datsun 1200 2Dr sedan.
From Seattle ,WA.
thanks for the idea's guys, I saw your switch setup Levey & was trying to think up a way to refine that with perhaps a micro switch mounted on the trans at the shifter so only in reverse it contacted the switch.
If I do end up cutting a hole in the tunnel does anyone have any pic's of exactly what ends up getting the chop? I just hand lifted the trans up last night to get a rough idea of where it would contact the tunnel & it looks like its on the back side of the right trans mount about 1/2 way up the mount, is that accurate & does one end up cutting off part of the mount to make it fit?
Thanks, Evan
Posted on: 2010/11/22 16:32
Re: 60A reverse switch ??? - Update
From Seattle ,WA.
here's a pic of the dreaded reverse switch interference with the trans mount....
I think I'm going to try a Levey style switch instead of chopping a hole into the tunnel & mount. I need to plug the hole, does anyone know what the thread size and pitch of the rev
hole is?
I can see the difficulty of this now and to not end up with a hack job its a bit more trouble than I expected, oh well such is life!
Posted on: 2010/11/23 4:39
Hi Evan, I had the same issue and wasn't prepared to modify the tunnel. I resorted to the cut and shut and have a flick switch and small buzzer ready to fit. To tell you truth I never tried that hard to get over that hurdle. Looking forward to seeing how it all turns out, some pics:
Posted on: 2010/11/23 5:06
From Seattle ,WA.
I do have multiples of that switch so i may try the cut & shut if I have to, would like to find a plug if possible. I think its an 18mm x 1.5 thread - I'll update when its solved along with the trans mount bracket as well.
Posted on: 2010/11/23 16:13
From Fremantle, West Australia
Evan
I think the coolant pulg on the side of a A series fits
I Have not got around to it but I think it would be possible to drill and tap and fit a switch into the casting "bulge" just behind the switch. (see Chris's photo )I have looked inside an extension housing and a rod with a tapered end slides
north / south and hits the original switch on the side.
By drilling and fitting a switch on the end, maybe the rod could hit a custom switch end-on.
The 5 speed 56 gearbox has the reverse switch with this orientation so maybe its do-able
Can anyone with a 5 speed 56 box post a pic of their reverse switch and where it screws in??
Posted on: 2010/11/24 3:00
Had a closer look today
Not sure if it is the exact thread but the very common 1/4"BSP plug fits in the reverse switch hole, not a tight fit so some thread tape or thread sealant required.
now that I know what thread to use, the next step will be to drill and tap the aluminium bulge and fit the switch behind the striking rod
Posted on: 2010/11/27 11:55
