« 1 2 (3) 4 5 »
Re: Reverse switch success!!
From Sydney
Is the problem now a physical space issue or a electrical logic problem? Is the switch you currently have, normally open cct or the normally closed cct. If the problem is now physical, are you able to turn up a threaded spacer [in alloy] to house the nose of the switch.
Posted on: 2010/12/21 10:40
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From Fremantle, West Australia
No the problem is my tunnel vision
In reverse neutral 1 2 3 4 all is good but then when you go for 5th the selector rod cannot move backwards because someone put a switch in the way. I think I will keep my bright ideas quiet in the future
Posted on: 2010/12/21 11:39
what about a low-profile switch? That fits in the stock hole but doesn't stick out much?
Posted on: 2010/12/26 2:18
56-series 5-speed has it here (pink arrow):
See Reverse Lamp Switch
Posted on: 2010/12/26 4:36
Not much room in the tunnel
Posted on: 2010/12/27 2:26
From Seattle ,WA.
the main problem on my 60A 5 spd is the placement of the switch - it interferes with the right side trans mount in the tunnel which means you have to cut up the mount to make it fit. I recall a picture of Ernie's yellow 1200 mount cut apart to make his fit. I'd do the hole in the tunnel if the mount wasn't in the road, I'll be using a micro switch off the shifter
Posted on: 2010/12/27 5:38
You can use a regular size switch too.
Posted on: 2010/12/27 5:56
what about the suzuki switch?
does it fit the stock a series box? if so should fit my 63 series dogleg too.
is it worth it or just do a nige and hope it lasts.
Posted on: 2011/1/13 12:32
From Perth WA AUS
Funny bugger!:)
If anyone can sort this problem out I believe it is weekend1000, stay tuned.
Posted on: 2011/1/13 13:37
Datsun 1200 2Dr sedan.
Posted on: 2011/1/19 7:50
« 1 2 (3) 4 5 »
