« 1 (2) 3 4 5 ... 9 »
Re: For those looking at Bike engines for a datto
make sure your on an incline :)
modified starter motor to also go backwards
http://www.ccw-tools.com/Automotive/R ... -Motors/c-1-597-599-2418/
Also if you mounted everything in the rear
http://www.westhouse.plus.com/chaindrive1.htm
Id love one on the back seat with a fuel cell
where the orig box and firewall is.
Posted on: 2010/12/27 23:46
From Delaware, USA
Good question !!! What about the reverse !!!
Posted on: 2010/12/27 23:54
From Ringwood, Melbourne, AUS
There are numerous reversing gearboxes available, there is a huge bike engined car scene in the UK.
Also means you have six reverse gears
These guys do kits for mini's amongst others, also reversing box's etc..
http://www.zcars.org.uk/
Posted on: 2010/12/28 0:12
Deano
From Brisbane
I've had a few fast bikes over the years, including a turbo'd 1402cc Suzuki.
A large capacity turbo'd bike engine would be fantastic in a lightweight shell. Critical that the car is extremely light weight, and that the engine is largest capacity possible.
Bike engines are traditionally targetted at high end power which is great, but in many cases they lack low-down torque. On top of this, to suit a heavier shell you need to re-tune the engine and it will make less power & torque than standard unless you turbo it or complete additional modifications.
That said, you can have some BRILLIANT results with this kind of thing.
Personally I'd look at a GSX1400, GSX1300R, ZX12R or ZX14 engine.
Posted on: 2010/12/28 2:14
i've heard of people just putting a starter motor on the tailshaft never seen it done before tho
Posted on: 2010/12/28 2:29
From Ballarat Victoria
I`d certainly love to do a bike engine conversion.
GSXR1300 lightly boosted would be my choice.
Problem is only being able to fit so much into one liftime!
Someone should have a crack. Be more fun than a CA or SR conversion. And turn a lot more heads too!
Posted on: 2010/12/28 3:10
You'd probably want to factor in that most bike engines don't last half the kms that a road engine does (esp the ones in very high hp per litre configurations) - and loading them up with a full sized car, rather than a bike (where you essentially get to a couple of hundred kms per hour quite quickly then typically back off a bit) loads them up a lot worse. Expect shorter engine life big time.
There's certainly more than a few mini conversions out there - most of them fwd, but some rwd. The best fwd conversions for the mini (in terms of overall performance - acceleration and handling - potential) are probably the honda engine conversions. Not a dead simple swap, but instantly gets you the power to snot (with a relatively stock honda motor) a full race BMC A series engine
Now specifically on reverse - some of the rwd mini conversions have a reverse setup. what they do is mount a second 'starter motor' backwards. It's electric and there is a lockout switch that only allows a complete circuit when you are in neutral. Basically what happens is you select neutral, then hit reverse (which is usually a button) and the starter engages on the flywheel, and you creep slowly backward. Since the car is light, it'll allow reversing (albeit at a slow speed) up an incline. But you'd basically only want to use reverse for parking, and where there was absolutely no other alternative.
I don't know if that would be legal in Australia, the conversions I've seen on the net are mostly in teh UK.
Another good fwd conversion for minis (and I suppose we might consider them for the fwd dattos if possible) is the suzuki swift engine. They produce decent hp in stock form (even though they are getting on 20 years old or more) . There's a bloke who has an open wheeled racer (I forget the class - if I remember I'll edit/update this post) - I think it's a 'maddox' . They have the option of running pushrod 1.3 litres with massive mods (he previously ran a toyota 3K engine, or they can use the swift engine, but very limited mods (have to run 10.5:1 compression maximum, and I think camshaft profile is also limited, and they are also mandated an 8500rpm redline_). Anyway, the swift motor essentially matches the output of the 3k, but does it at a lower rpm (slightly) and has more 'area under the curve' - more torque and broader powerband, so it's a lot faster than the peak hp figure comparisons might otherwise make
I'll say this - if someone was to pursue it, there's nothing quite like driving a full on NA race engine screaming at high rpms with a very close ratio gearbox to suit it. Takes a driver that knows how to get the most out of them, but once you find that 'groove' where driver and car are in sync, they are fantastic.
Posted on: 2010/12/28 4:21
John McKenzie
The "Aussie race cars" (legends) are about 450kgs and make about 135Hp from a FJ1100 air cooled bike engine. theses things look like alot of fun.
The Aussie versions run a Celica diff and solid rear discs. one of these discs has spur teeth machined into the outer edge with a starter mounted on the diff for reversing.
Posted on: 2010/12/28 4:40
Im changing this thread to "motorcycle engine thread"
that way others can put any link and stuff on here.
The best and cheapest reverse box is this one at 1050usd plus shipping.
http://thekneeslider.com/archives/201 ... -cars-from-roadstercycle/
http://www.roadstercycle.com/
I was looking at my datsun 1000 with a rwd setup using
the modded chain drive diff and independent rear end.
The Volvo 360 rear end suits all our datsuns leaf springs
eg.
jpg  volvo343.jpg (33.94 KB)
737_4d19783ac5f82.jpg 462X352 px
jpg  volvo 340.jpg (33.64 KB)
737_4d197841d74fc.jpg 526X313 px
jpg  340sus.jpg (47.40 KB)
737_4d19784a26aa1.jpg 714X336 px
Posted on: 2010/12/28 5:35
Re: Motorcycle Engine Thread MET
You dont have to run chain drive. The chain sprocket on the gear case is changed 4 a unijoint flange. You then run a standard type tailshaft. The engine is mounted north south obviously.
Posted on: 2010/12/28 8:33
