« 1 2 3 (4) 5 6 7 ... 10 »
Re: D.I.Y. Dyno
since when do datsuns fdo 195kmh... seems to be your first glitch hahahaha
joke. just give me my $100 simon, oh that was a differnet thread
Posted on: 2010/12/28 23:40
Re: D.I.Y. Dyno
From Ballarat Victoria
I must get onto finishing the tune! It broke the gearbox before it was tuned. Another thing for the to do list. I am a little embarressed about not finishing it by now and handing over the dosh!
It was the wifes corolla under no load that i was using for the test.. 6100 in 5th.
Posted on: 2010/12/31 9:12
VIC DYNO HIRE
Re: D.I.Y. Dyno
You broke the 71b box or your wife's corolla box????
Posted on: 2011/1/1 2:17
Re: D.I.Y. Dyno
hope it was a sportivo corolla, but then you should have got it to 8200 rpm in 6th
Posted on: 2011/1/1 2:53
Re: D.I.Y. Dyno
The 71b box.... It didnt realy break, the nut spun off the output shaft. lost 5th and reverse. I`d only tuned to 5,500rpm when it let go. Thats why i havnt got a HP figure yet for the "Guess the HP" thread.
Ive fixed it now but havent had it back on a dyno to finish tuning.
Posted on: 2011/1/1 4:19
VIC DYNO HIRE
Re: D.I.Y. Dyno
fifth is 1:1 on that special box or stock overdrive?
Hope its not too expensive to fix as the later 71b boxes
are common and behind many low power CA engines.
Posted on: 2011/1/1 4:32
Re: D.I.Y. Dyno
Im back onto this project. here`s a couple of pics of the controller enclosure and cable boom.
Ive still got some wiring to finish.
Posted on: 2011/7/10 6:54
Edited by sikyne on 2011/7/10 7:12:09
Edited by sikyne on 2011/7/10 7:13:38
Edited by sikyne on 2011/7/10 7:14:40
VIC DYNO HIRE
Re: D.I.Y. Dyno
Same colours as your race 1200 coupe :))
Posted on: 2011/7/10 7:51
Re: D.I.Y. Dyno
From mandurah
Nice work ! ,not many people would attemp to build there own dyno ! Props to you ....
Those retarders look like the telma retarder on a mack ,might have been easyer to get them from a wrecking yard
Or am I confused with something completely different :D
Posted on: 2011/7/10 8:06
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Re: D.I.Y. Dyno
Spot on. A few people use S/H truck retarders. They are 24Volt and have to be rewired to 192 Volt. Not realy a big job. When buying new, you get to choose Size, voltage, shaft design etc and you know they work.
I have bought a secondhand unit for a friend before and machined up shafts to suit his dyno frame.
Its probably a bit difficult to get two identical retarders to suit a hub dyno tho.
Posted on: 2011/7/10 8:44
VIC DYNO HIRE
