Browsing this Thread:   4 Anonymous Users
widest legal wheels on a 1200 ?
From Central Coast NSW
hey guys
just wondering when i go to get my 1200 engineered for sr20.
what is the widest wheels i can run on them
it has bolt on flares.
i have 14x6.5 ssr starshark wheels on the front.
but 14 inch stockos on the rear.
was wondering if it was legal if i filled the flares with 14x8 rears and could get it engineered?
jpg  165388_10150148041678327_764393326_8159446_5004316_n.jpg (61.17 KB)
12738_4d22f46e6d21e.jpg 720X540 px
Posted on: 2011/1/4 10:18
Re: widest legal wheels on a 1200 ?
From Geelong, Vic
pretty sure that is up to the engineer, as they can engineer it for larger wheels.
the widest you can go unengineered is 5 or 5.5 inch i think
Posted on: 2011/1/4 11:12
From Sydney
all i know as i got my 1200 sedan engineered recently is that due to the weight of the vehicle the widest i could go was 6"
Posted on: 2011/1/4 19:21
From Sydney, Australia
just do it!
Posted on: 2011/1/4 21:38
B110 sedan
Id keep the 14 x 6.5 it will be enough for grip
if you had good quality tyres.
Posted on: 2011/1/5 1:20
25mm wider than stock, so that makes it 1 inch, so 5.5 is widest leagl by vic roads and adrs.
Posted on: 2011/1/5 7:57
unless you can prove it had 5.5 inch steelies from factory
which I did with a later tire chassis sticker on one of
my old Mazdas.
Posted on: 2011/1/5 11:50
not on a 1200, they all had 12 x 4.5 in aus so 5.5 biggest.
Like the engine swaps, you really need to read this in vic- vsi 8
i know its 2003 but until the national system gets the nod and agreement form all states, it still stands.
Posted on: 2011/1/5 11:54
From sydney australia
In NSW it used to be & still could be that the widest wheel for a car under 1000 kg was 6 inches. The heavier the car, the wider the wheel could be. It had nothing to do with whats on the tyre placard, as most insurance companies will try & tell you. The 1200 came standard with a 12x4 inch wheel so we'd all have to find 5 inch wide wheels. I think you can get them engineered with wider wheels, but it's up to the engineer & you're stuck with that size unless you want to re-engineer the car. If you're putting an SR20 into it, surely you've talked to an engineer. I'd suggest you give that engineer a call & ask his opinion. A 6 or 7 inch rim with some 185-195 wide tyres has plenty of grip. Another thing that I found out is that the wider the tyre the less weigh there is on the contact patch of each tyre & the less grip you get, & the more likely it is to aquaplane in the wet. I've run 175/60 x14's on 5 inch steelies as wet weather tyres before, as well as 185/60x13's on 6 inch rims. This allowed for good grip & good wear. I seemed to always get 2 years running out of a set of tyres. Even when I was delivering pizza's I'd get 12 months worth from the Sunny I had, with some 195/60x14's on 6 inch rims. I reckon the 14x6.5's you've got with some 205/55x14's would be a good thing, because of the extra weight of the car after the engine swap.
Posted on: 2011/1/5 12:26
Some good advice here, especially too wide issues with lightweight cars
Posted on: 2011/1/5 23:40
