S13 brakes - CA vs SR - do they use the same adaptor?
From Ringwood, Melbourne, AUS
Can anyone tell me if the adaptor to fit S13 CA brakes to a standard 110 strut will also allow SR brakes to be fitted? Or do you need another, SR specific, adaptor?
I realise the diameter of the disc is larger but not sure if the SR caliper has longer mounting lugs to suit or not?
Anyone done both?
Posted on: 2011/1/2 1:10
Deano
Re: S13 brakes - CA vs SR - do they use the same adaptor?
From Melbourne AUS
although im not 100% sure i do think its the same caliper bracket.
ive even heard the same bracket will bolt up r32 skyline calipers, but ive never tried.
Posted on: 2011/1/2 4:30
1973 B110 A12
Well my R34 calipers have the same spacing as my S13 CA calipers so I can say they will bolt to the same adaptor but the big thing will be what is the radius it places the caliper on compared to the disc..?
EDIT: Sorry, same spacing but R34 calipers use a M14 bolt rather than the M12 as per R33/32/S15 etc..
Just comparing by hand the alloy R34 calipers seem lighter than the iron S13 CA ones..
Posted on: 2011/1/2 7:21
Edited by ssskiwi on 2011/1/2 7:51:47
Deano
From Brisbane
I'm fairly sure that the swap from CA to SR brakes on a silvia is a straight bolt-on... if that's the case then the SR brakes will bolt to the same adapter as a CA.
Posted on: 2011/1/2 11:56
From cranbourne, vic
yes they swap, i have SR brakes on CA s13 knuckles. you can even use s14 four pots and rotors (if redrilled to 4 stud)on the s13 knuckle, so i would think you could even use those with the same kit?
Posted on: 2011/1/2 12:15
82 1200 ute - daily
89 R31 H.M.A.S. Skyliner - drifter
197? 1200 coupe - new drift project.
85 CMA81 nissan/ud 9.5ton banana back - tow pig for the drifter.
Sweet, thanks for the info..
I will get the CA stuff fitted up then and when I get the bigger rims I have my eye on will look around for some SR stuff (or maybe even fit up the R34 ones )
Posted on: 2011/1/2 12:25
Deano
From Sydney
So now im confused, can the s13 brake swap be done on 1200 disk struts?
I was checking in wiki and it seems to mostly be done on 120y struts?????
cheers
Posted on: 2011/1/7 23:15
From Townsville, Qld
The reason for 120Y struts is merely cos they're pretty close\available to the 1200 items, drum hubs need no machining whereas disk hubs do require a small amount off the outside to let the disk slip over it.
Posted on: 2011/1/8 1:36
As I understand it, the early 120Y struts and calipers are the same as the 1200 disc ones?
Then the later used the PBR caliper and had different hubs??
Posted on: 2011/1/8 1:42
Deano
that'd be more on the money, I've only played with the jap stuff on my cars so
Posted on: 2011/1/8 4:23
