120y 15 inch skyline steelies
I cannot get my 15 inch skyline steelies to fit on the front of my 120y coupe. :(
They hit the spring perch.
I'm not sure if running smaller tyres will fix this?
Is there any simple swaps for a 120y (b210) to make the 6 inch wheels fit?
I've been looking around and stanza struts are supposed to fit but can anyone give me more information on this?
thanks.
Posted on: 2011/1/9 2:49
Re: 120y 15 inch skyline steelies
From Townsville, Qld
running 120y struts at the moment I guess. 180B/200B/Stanza hubs are what you want on either of the struts for them. First two need the spring perch chopped off and a smaller one welded back on so they fit in the towers. Bluebird and R31 struts would fit them as well but I think you may need the lower control arms and attached gear to run them
Posted on: 2011/1/9 3:26
From Goulburn NSW
try talking to maddat in adelaide they will be able to sort it out for u
Posted on: 2011/1/9 8:25
From Geelong, Vic
have a look here
they will fit with any of the larger struts. 1200 and 120y struts dont have the right stub axle angle to run those rims. pretty sure they also hit the actual strut body not just the spring perch
so you need to run some pretty fierce spacers on the 120y struts or swap to a larger datsun strut
Posted on: 2011/1/9 8:59
From Brisbane
I had steelies on the front of my 120Y, but they were narrowed to 4" so I can't offer any advice.
Posted on: 2011/1/9 23:01
