(1) 2 3 »
Early or Late Model Engine
From Sydney, NSW
Hi i was just wondering if my engine is the earlier or later model engine.. i heard based on dizzy position it requires a different resistor?
please see pic attached
Cheers,
Tom
jpg  dizzylocation.jpg (93.86 KB)
12667_4d2b967daed1b.jpg 640X480 px
Posted on: 2011/1/10 23:30
Re: Early or Late Model Engine
From mandurah
that there is a late A12 ,being that the dizzy is at the rear of the motor instead of at the front ,where the alternator is in your pic
hope this helps !
Posted on: 2011/1/10 23:34
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Sydney, NSW
Thanks so much for the speedy reply! most appreciated! awesome! time to order a replacement dizzy!
Posted on: 2011/1/10 23:36
From Sydney, NSW
so with the late model engine I'd need a fuel pump from a post 1973 model 1200?
Cheers,
Tom
Posted on: 2011/3/9 22:10
From Coondle, WA Australia
Nah i dont think so.
The mechanical fuel pumps are interchangable im pretty sure.
or you could blank off the hole and use a cheap low presssure electic pump.
Posted on: 2011/3/9 23:09
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From Sydney, NSW
Cheers reuby!
does somewhere sell the blanking plates? and re the electric pump what would you suggest from where?
Posted on: 2011/3/9 23:15
whats wrong with your pump? isnt it all there already? if so just connect your fuel line
and add a resistor (little white chewing gum sized ceramic box) and thats it.
Posted on: 2011/3/10 1:42
From Sydney, NSW
It's playing up.. im not getting enough fuel to the carby when going uphill! haha it's quite funny the first few times but now im over it!
I bought the replacement pump from ebay but is the early model one so im just wondering do i sell it and buy a later model one or just go electric..
Posted on: 2011/3/10 1:51
The fuel pump should work fine the only differance would be the crank arm and or the bolt plate may be smaller! Hope this helps if not u can look at the wiki
<---------- on the side bar that will also help with other problem you may have! Nick
Posted on: 2011/3/10 2:46
Car free
you can hunt one down from a wreckers as they usually down wear out easily.
Have you tried pulling it apart? you might be able to change arms.
Posted on: 2011/3/10 3:03
(1) 2 3 »
