« 1 (2)
Re: intercooler color
From Perth Austarlia
Yes, This question has always intrigued? me. when thinking about heat being radiated outwards, what the f%@k does the outside surface colour have to do with it ?????
I think its' an old wifes tale..
It might be that a painted surface has more surface area (at a microscopic level) but surely, any covering acts as a thermal insulator??
Posted on: 2004/1/19 15:35
From Brisbane, Australia
it's no old wives tale. if you do a search on heat emmisivity you may turn up some university materials explaining that matt black surface are much more efficient at emitting heat energy to air than natural aluminium surfaces. Polished alloy surfaces (as I stupidly did to my rocker cover) are even worse at emmiting heat.
I have no doubt the natural alloy finish became popular for aesthetic value only - what's the point of having the big front mount if no-one can see it?
If you do paint them, use matt black, and mix the paint as thin as possible.
Race engine builders (circuit & rally anyway) have long been painting blocks and rockers matt black inside and out to help with heat transfer. Before anyone mentions drag cars and their intercoolers and polished engines etc - don't bother. Serious drag engines run without any real cooling system at all, just filled blocks. An activity taking under 10seconds is not goint to benefit much from black paint, as there is bugger all time to transfer any worthwhile amount of heat out of the systems anyway. They use the stupidly large intercoolers as much for the heat soak area as for charge cooling!
Posted on: 2004/1/20 8:26
I just did a quick search myself... here's something from Northern Illinois University, Department of Mathematical Sciences:
The emissivity of a dark hole drilled in a cube of carbon at the MBS is the blackest thing around, and has a value of 1.00. Flat black paint has an emmisivity of around .95, while that of polished aluminum foil (brighter than Reynolds wrap) is only 0.05.
Posted on: 2004/1/20 22:57
From Sydney, Australia
Yes..The high pressure side of the blow off valve should be plumbed as close to the turbo side of throttlebody. The plumbback (if not vented to atmo) is plumbed back to the low pressure side of the turbo, before AFM.
Posted on: 2004/1/20 23:08
From Mandurah WA
1200rallycar wrote:
yeah im gonna paint it then, just dont want to give myself away
im also gonna plumb the bov back into the system, i really want the pshhhhhhhhhh sound dammit, wheres the best place to plumb it back, in the inlet after the afm and before the turbo i pressume???
After the afm never before :)
Its the only place where its gotta go.. other wise you will cause serious damage
Posted on: 2004/1/21 5:15
1984 Mazda 626 stocker..
Soon to be 32/36 weber powered
« 1 (2)
